Zonda Cat 41" from Horracing
  • twissted
    • Jul 2012
    • 867
    #181
    It would be nice to see the TFL boat products sold here. I think that they would do well to do so.
    • rude5150
      • Feb 2014
      • 339
      #182
      Have you the TP4060 1870kv motor?
      About how much faster is TP vs LEOPARD motors?
      • twissted
        • Jul 2012
        • 867
        #183
        no I have the 4050 series from tppowewer it is a 3Y that is 2220kv and I will be about 10 mph fast than if I was to use a leopard motor of the same size and KV. It maybe more than that leopard doesn't have a motor that will run 6s of this size and kv that I know of.
        • twissted
          • Jul 2012
          • 867
          #184
          If your going to the 4060 series then look at the 5D wind that is 2040kv. 6s is no problem with this motor. Big power!
          • rude5150
            • Feb 2014
            • 339
            #185
            What's your speed on that setup?
            • rude5150
              • Feb 2014
              • 339
              #186
              TO 4060 2040LB 6S VS TP 4060 1870LB. WHICH IS FASTER? DOES MORE KV= faster?
              • twissted
                • Jul 2012
                • 867
                #187
                yes the kv is how many times it turns with a rated amount of voltage. Google it to learn more.
                • rude5150
                  • Feb 2014
                  • 339
                  #188
                  Then I should get 4060 2600lb 4D?
                  • rude5150
                    • Feb 2014
                    • 339
                    #189
                    2600kv
                    • bracka69
                      • Jun 2011
                      • 298
                      #190
                      A lot of people recommend the TP4050 over the TP4060. They say they handle the higher rpms better. A lot of people have gotten good results running the 4050 2350kv on 5s and 6s for Saw runs.
                      • rude5150
                        • Feb 2014
                        • 339
                        #191
                        My Zonda cat is here.I'm on the bus now. Anyone having luck with TP 4060 2600kv?
                        • twissted
                          • Jul 2012
                          • 867
                          #192
                          bracka69 has it right. I like the 4050 3Y 2220kv and will be running 6s.
                          The zonda you have will need to have some work done to handle that kind of power. Triple digits is no joke and with destroy your boat if not built right or driven properly.
                          Have you driven any rc anything that fast or with that kind of power?
                          • rude5150
                            • Feb 2014
                            • 339
                            #193
                            Is Y wind faster than D wind motors?
                            • rude5150
                              • Feb 2014
                              • 339
                              #194
                              Noting that fast yet. Is Y wind faster than D wind motors?
                              • rude5150
                                • Feb 2014
                                • 339
                                #195
                                Should I use the swordfish 300amp, 220amp, or speaking 180? Whats the better esc for TP 406050?
