Zonda Cat 41" from Horracing
  • Tbauer
    • Aug 2012
    • 261
    #241
    Dude, sorry to see that mess........ I feel your pain, been there, done that, even scuba dived for one of mine......... RIP
    • rude5150
      • Feb 2014
      • 339
      #242
      I used fiber glass resin and hardener.
      • drwayne
        • May 2008
        • 2981
        #243
        Originally posted by rude5150
        How fast were you going ? How did you crash?
        everyone who watched the incident has a different story of what they saw.
        it happened quick, involved a sudden bit of side draft and lots of spin... oh ~85mph too lol
        'everyone' saw the cowl thrown off in the death spin.. however the hull was recovered with cowl still taped !
        it may get run through a bandsaw to make a wall mounted trophy.. hahaha
        • drwayne
          • May 2008
          • 2981
          #244
          btw, the hull is not mine
          Belongs to 'Jamie' here at OSE.
          • tlandauer
            • 5666
            #245
            drwayne,
            which viscosity version of CorrosionX was used in your ESC? I am impressed that it didn't get washed away for so long under water.
            • drwayne
              • May 2008
              • 2981
              #246
              drwayne,
              Hmm.. it's the blue gear.
              part no.91002 for ~ a pint of the stuff
              heatshrink removed.. esc literally drowned in X for hr or so.. removed.. drip dried..heatshrink applied.. esc installed and used...
              I simply pour X through the esc every few weeks of use after the above treatment..
              Also ... invert servo, open base, flood with X ..replace base..use ..no issue ever with water or lubrication of gears
              Ditto Rx or BEC
              Be aware where dip switches are used, it is wise to cover those with a drop of silicone .. as the X may penetrate and cause conductivity issues..
              The watershed quality of X is used by nitro runners who flush motors with this gear.. !
              regs
              W
              • Chrisg81983
                • Jul 2011
                • 1556
                #247
                Yeah I figured that lol. but what brand there are hundreds of makers. For example west systems or some stuff from local hardware store. There was a reason I was asking thanks and talk to u soon
                • tlandauer
                  • 5666
                  #248
                  Ditto Rx or BEC
                  regs
                  W
                  Thank you drwayne!
                  Reason I asked was precisely I thought you used the blue gear, it is thicker and I have to order it from else where. Also thank you for sharing in DETAIL how you apply and maintain the X on the ESC, rx, servo, etc.
                  Valuable advice for everyone!
                  • borgie
                    • Dec 2012
                    • 101
                    #249
                    Carbon Zonda Crash
                    Hi there Borgie here (the one Doc mentioned before),
                    today (friday) i got some air time with my Zonda and it punched the side in , the seam is fine it fractured right on the sponson edge of the right side and ripped the left hand side motor out and the deck also had some fractures, we did a rough and ready repair job... it will be ready tomorrow (saturday)
                    P.S: all electronics survived due to being corrosion X-ed the boat took on a lot of water and i would recommend corrosion x to anyone!
                    • drwayne
                      • May 2008
                      • 2981
                      #250
                      Borgie's old man ( Borgie senior) runs a auto repair shop and also builds/races boats for the fullsize clubs throughout Australia.
                      His own blown mono is entered in this year's UIM Races !!!
                      Borgie senior told me a few moments ago that the above broken hull is repaired & ready for a run this morning ( 24hrs after above damage !! )
                      Great work father / son team !
                      • Fella1340
                        • May 2013
                        • 1035
                        #251
                        There doesn't look to be much in the way of material there for a sponson bottom! On the topic of corrosion x it's sold under a bunch of different uses. I ordered a 6 oz bottle and received the corrosion x for gun care. Naturally concerned about using it on electronics I contacted corrosion x and was informed it's the same formula sold under a dozen different use types! Good marketing I suppose.
