Thanks again make a wake. I'll get some of this stuff ordered. I'm not looking forward to the battery bill. Any suggestions on these. Each pack should be 3s 11v correct ? How about a c rating?
1/8 hydro
I looked back over the thread and see no mention of cells?........9s right?
I would recommend 9s, you can swing a bit larger prop that way. You will need 6 3s batts, i think thats better than two 4s and two 5s myself, but to each his own.
The C rating is actually not hugely important running 2p(although no 20/25c for sure), but i would get 30c minimum............35c would be nice though too.
Six of these for 300 continuous amps and 10,000 mah
http://www.hobbyking.com/hobbyking/s...idProduct=8587
or six of these for 348 continuous amps and 11,600 mah
http://www.hobbyking.com/hobbyking/s...idProduct=9932
You will need to make two parallel connectors.
This is a pic of my parallel connector for my 39" mono, but for my Hydro is used two 5.5mm bullets that fit the stock batt connectors and soldered the two wires into one big 8mm bullet.Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
i actually see the 9s2p in your signature . if it is anyplace else sorry for the repeat . how does 6 2cell packs equal 9s ? am i missing something ? sorry , this lipo breakdown i`m sure has been done about a million times .Comment
The packs i suggested in post #32 are 3s packs. 3 x 3s = 9s x 2 sets = 9s2p.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
so its been a while but i was able to get most of the motor mount completed today . i had to machine up an adapter for the proboat coupler its in the pic as well . i`ll take it out and get some close ups of that
photo (1).JPGComment
here`s a few other pics of the mount and coupler
motor and mount
how about this setup
photo (2).JPGComment
Any action here????NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Slow. I'm nearly finished. I'm waiting on some batteries. I bought an eagle tree data logger from the swap shop. I would like to get all the goodies so I can find a home for everything.Comment
Great, looking forward to seeing her run!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Hello gentlemen, it's my first post
lots of good info here, as i'm starting a 1/8 Miss Renault'83 build 42" Newton plans (ply). after reading this, i believe i'll power it with a castle 2028 & a swordfish 240 hv
it's my first electric boat (have electric planes tho) so i'm a sponge... sort of
i might start with 8s and see.
need some advice on the hardware pls. if someone has the part no. for the cooling jacket for the 2028, let me know
Thanks, VasekComment
take a look at make a wakes post #30 there is a link to the manufacter of the cooling jacket . i have one it is simple yet effective .Comment
...i might start with 8s and see....
