1/8 hydro
  • magnum500sw
    • Jan 2009
    • 97
    1/8 hydro
    well i am finally going to finish this build off . it is a pro boat formula hull . i have a castle 2028 780 kv motor going in , will be running stock hardware .
    my question is what speed control should i run the cc hydra 200hv or the hefei swordfish 240 hv ?
  • K.R.Joye
    • Feb 2010
    • 1046
    Get a Swordfish 240 HV from OSE, they are plug & play, run cool and are good solid controllers for the money. Castle HVs have poor track record.
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
    • magnum500sw
      • Jan 2009
      • 97
      thanks k.r. i am actually glad to hear that controler has a good reveiw . i am going to build a motor mount this weekend , should i water cool it ? i`ll take some photo`s and post them
      • K.R.Joye
        • Feb 2010
        • 1046
        Watercooling is a must for an HV setup. Run your cooling to the ESC first then to the motor.
        • magnum500sw
          • Jan 2009
          • 97
          i meant the motor mount , i guess i should have expanded on my question . just for curiosty sake , who sells a mount for the 2028 ? i guess i should see a price first befor i commit myself to a scratch build . thanks for the advice , because i thought the motor cooled first .
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Water cooled mounts arent needed for inrunners. They really don't do a thing for outrunners either. I don't know who makes a mount for a 2028. You can make your own fairly easily though.
            • Cottageboater
              • May 2008
              • 779
              For the motor mount, contact Jim at south river rc. Thats where I got mine.
              • Make-a-Wake
                FE Rules!
                • 5557
                Here's the 2028 mount i made for my 1/8 Hydro
                • magnum500sw
                  • Jan 2009
                  • 97
                  thanks larry . that will save some building time
                  • magnum500sw
                    • Jan 2009
                    • 97
                    looks easy enough . i thought the back of the motor would need some support . thanks for the pics
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      I have a rear support bar i made after the photo...........the whole mounting system is darn near bulletproof.
                      • magnum500sw
                        • Jan 2009
                        • 97
                        i figured that big honkin motor could use the support in the back . is it a clamp or just a rest
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          You can see it in this pic....................its a steel bar rest, but its fastened to it
                          • magnum500sw
                            • Jan 2009
                            • 97
                            who makes your hull make-a-wake .
                            • K.R.Joye
                              • Feb 2010
                              • 1046
                              Best way is to find some good aluminum plate & angle and make your own mounts. Most motors can be securely mounted off the shaft-side end bell face(even the big ones). You just need to the right gauge mat'l and good quality fasteners. You don't need a CNC machinne to fabricate this stuff, its amazing what you can do if you own a square, power-drill, hacksaw, file/sandpaper etc.
                              I'm lucky enough to have a small Drill Press, 12" Disc Sander and Band Saw along with other tools in my workshop. Can build or fix just about anything with the hobby.
