r2hobbies outrigger
  • regisparent
    • Aug 2009
    • 16
    #61
    I haved try mine yesteday with no succes.. stock sv 27 motor ( approx 1550 kv) with 3 s battery. the boat never lifted.
    • darioellider
      • Dec 2009
      • 19
      #62
      Excuse me I been on vacation here in Seville was Semana Santa, is a very popular holiday and not work in two weeks nothing and we the party of La Feria de Abril.
      This is why in these days I have not tried anything nor have I recorded video.
      Try to record a video with green plastic prop 37mm, I assure you exceed 100km / h.
      I do not intend to deceive anyone and try to do the video with gps, but give me time.
      siberianhusky, With 4S lipo battery is good for competition if it does not exceed 100km / h, all the boats of 4s exceed 100km / h here in Spain.
      This is very normal.
      Some boat has exceeded 150km / h but not the autonomy of 5 minutes, the running time
        • 9488
        #63
        I would use 4s or 5s on that motor
        • siberianhusky
          • Dec 2009
          • 2187
          #64
          Oh no he's back! LOL
          Yep 4 or 5s would wake up the SV setup!
          • electric
            • May 2008
            • 1744
            #65
            100 km/h = 62 mph
            • ray schrauwen
              • 9472
              #66
              Sorry, forgot you started thread with pictures.
              Nortavlag Bulc
              • ray schrauwen
                • 9472
                #67
                Looks like a Leopard 4068, 2500KV motor.
                I think my 4068, 6pole 2560Kv motor will do jmust fine.
                Nortavlag Bulc
                • darioellider
                  • Dec 2009
                  • 19
                  #68
                  if you read you will know which engine I use
                  540L = 3660
                  Probe it, Please.
                  if you want to run for 5 minutes you must to used 37-37,5mm prop, 2 blades, 1,4 pitch.
                  if you want speed you must to used 39-40mm prop, 1,4 pitch or V936 octura
                  • ray schrauwen
                    • 9472
                    #69
                    Is this not a Leopard?
                    Or, did I make a mistake on the size?
                    3660, o.k. I see... Nice.
                    I will still use my 4068.
                    So is your motor a Leopard 3660 or something else?
                    Nortavlag Bulc
                    • martin
                      • 2887
                      #70
                      A 3660 / 2500kv motor on 4s should give the following speeds
                      37mm prop =53mph or 85kph
                      40mm prop = 58mph or 93kph
                      v936 prop = 70mph or 112kph.
                      • darioellider
                        • Dec 2009
                        • 19
                        #71
                        that prop is reached those speeds?
                        octura X, Y, V, M,etc...
                        Etti
                        H&M
                        Graupner
                        marlech
                        tenshock
                        Pratter
                        they are all different and there have different pitch and 2 or 3 blades, etc...
                        • darioellider
                          • Dec 2009
                          • 19
                          #72
                          that hull?
                          that gc?
                          • martin
                            • 2887
                            #73
                            2 blades x1.4 pitch apart from the x1.9 pitch. Thanks
                            • darioellider
                              • Dec 2009
                              • 19
                              #74
                              I do not use the octura x1.4, it has a lot of acceleration, much consumption but little speed.
                              i use Etti prop
                              • martin
                                • 2887
                                #75
                                I also use Etti props as well, Can you give the set up you use on your + 140kph boat , I assume 3660 2700kv on 4s & what make of prop & diameter + pitch did you use for + 140kph. Thanks.
