Mhz mystic 114 build
  • BUMBLESPECIMOODA
    • Feb 2023
    • 218
    #166
    More hatch progress:
    • BUMBLESPECIMOODA
      • Feb 2023
      • 218
      #167
      Fore hatch to vent flotation section during storage.
      • BUMBLESPECIMOODA
        • Feb 2023
        • 218
        #168
        Aft hatch will be used to turn on ESC's.
        • fweasel
          master of some
          • Jul 2016
          • 4281
          #169
          Are you going to hinge the hatches?
          • BUMBLESPECIMOODA
            • Feb 2023
            • 218
            #170
            Yup. Worked on those this morning. I'll make wee levers too.
            Gotta make 8 more for 20 in total. 2 hatches functional, the rest for decoration.
            • BUMBLESPECIMOODA
              • Feb 2023
              • 218
              #171
              Ready for deck install
              Satin-clear-coated all the carbon work, semi-permanently installed the stuffing-tubes (permatex black gasket silicone), neoprene-foamed the battery mounts, and whatever else I can do, before jamming the deck on.
              Then, the laborious task of prepping the entire outside surface.
              • BUMBLESPECIMOODA
                • Feb 2023
                • 218
                #172
                Got the recovery boat...
                It will also take care of the itch to get in the water.
                • BUMBLESPECIMOODA
                  • Feb 2023
                  • 218
                  #173
                  Slowly getting this rig mudded and faired. One of these months, it will be prepped & ready for paint. Progress pics will happen soon.
                  Reshaped the inner-tunnel strake, smoothly into the sponson tip. I don't know what was going through the mind of the designer, with the original shape...
                  • BUMBLESPECIMOODA
                    • Feb 2023
                    • 218
                    #174
                    Water-exits installed. Left-over tube from the pick-ups.
                    • fweasel
                      master of some
                      • Jul 2016
                      • 4281
                      #175
                      I've always been a fan of recessing them at an angle to the exterior surface. I think the ovalized opening gives them a more sleek appearance.
                      • BUMBLESPECIMOODA
                        • Feb 2023
                        • 218
                        #176
                        [ATTACH=CONFIG]179702[/ATTACH]
                        True that.
                        • BUMBLESPECIMOODA
                          • Feb 2023
                          • 218
                          #177
                          I counted them. 8,000,000,000 pinholes.
                          Inspired to get me nose to the grindstone, from the fine finish on pberzins76's boat.
                          • BUMBLESPECIMOODA
                            • Feb 2023
                            • 218
                            #178
                            Crush-sleeves bonded into the now solid rudder area.
                            Storage / travel case arrived too. Nanuk 996.
                            • BUMBLESPECIMOODA
                              • Feb 2023
                              • 218
                              #179
                              Sharpening edges now:
                              Masking tape removed, leaving high graphite resin, ready to be block-sanded.
                              • TheNorwegianPhilip
                                • Aug 2024
                                • 8
                                #180
                                Your work looks amazing!
                                You have given me many good suggestions for my build, and I?m looking forward to seeing the finished product.
                                I?ve just started my own build and had great ideas for show-quality finishes, but I see I need to step it up :P
