Mhz mystic 114 build
  • BUMBLESPECIMOODA
    • Feb 2023
    • 220
    #151
    CONTINUED...
    After the dunk-test fully equiped, it will be revealed if more floatation is needed. There's plenty of realestate between the cowl and the bridgedeck. One of the reasons why I did not mount the ESC's etc. there. I can put a huge chunk of foam there.
    • fweasel
      master of some
      • Jul 2016
      • 4291
      #152
      Hard to tell without the canopy opening in place for reference, but I hope you've left yourself enough room for the batteries to be slid forward.
      Vac-U-Tug Jr (13mph)
      • BUMBLESPECIMOODA
        • Feb 2023
        • 220
        #153
        Lots of room. With 6500mAh packs (the biggest I think I'll be using), cg tested good with them as far back as I could get them, without touching the ESC's. With smaller packs like 5000mAh, lots of room for sliding to front.
        BTW folks, I found a perfect spot for running these wee boats. Having done that, I'm going nuts not to be able to go play with them. Might have to get a ready to run ProBoat or something, to take care of the wait.
        • BUMBLESPECIMOODA
          • Feb 2023
          • 220
          #154
          Water pick-up tubes ready:
          • fweasel
            master of some
            • Jul 2016
            • 4291
            #155
            Where did you source the small diameter carbon braid? I've been looking for something like that to do exactly that same waterline wrap.
            • BUMBLESPECIMOODA
              • Feb 2023
              • 220
              #156
              ALIEXPRESS.
              It was 4mm ID.
              • fweasel
                master of some
                • Jul 2016
                • 4291
                #157
                Thanks!
                • BUMBLESPECIMOODA
                  • Feb 2023
                  • 220
                  #158
                  Pick-up tubes ready. Barbs made from mud. They will be installed through the hull tonight. Pics to follow.
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4291
                    #159
                    I love the silicone hose form used for the barbs. Great idea.
                    • BUMBLESPECIMOODA
                      • Feb 2023
                      • 220
                      #160
                      I saw a fella using pieces in place of zipties, on another thread. It gave me the idea for the mudding template.
                      • BUMBLESPECIMOODA
                        • Feb 2023
                        • 220
                        #161
                        Started on some hatches. One will be to vent the front sealed section, and the rear one to possible do something...
                        • BUMBLESPECIMOODA
                          • Feb 2023
                          • 220
                          #162
                          Cont...
                          • mmars89
                            • Jun 2021
                            • 50
                            #163
                            Absolutely beautiful and inspiring work my friend. Wow. Following.
                            I'm about to start a Mystic 114 build, thanks for sharing!
                            Cheers
                            • Alfa Spirit
                              • 2131
                              #164
                              Originally posted by BUMBLESPECIMOODA
                              Tried a slick coat of clear on the scoops too. Nect will be the bandit mask and the carbon rudder parts.
                              [ATTACH=CONFIG]179241[/ATTACH]
                              I think that with the black grids it would be much more realistic.
                              • BUMBLESPECIMOODA
                                • Feb 2023
                                • 220
                                #165
                                Cheers
                                I will be happy to follow your build as well.
                                I might just do that.
