Zippkits jae 21fe v2 outrigger_wood kit build
  • zooma
    Local club FE racer
    • May 2014
    • 652
    Originally posted by Peter A
    How's the CG?
    I think he will have to move the ESC forward of the motor.
    Ron - The Villages, FL
    • sammyha
      • Jul 2018
      • 1038
      I think you're right. I've been reading the 6s jae thread, looks like everyone has the esc in front of the motor.
      Also sounds like the CG two inches behind rear of turn fin is good. That's the 60/40 ratio the JAE21 likes...
      • HTVboats
        • Jun 2011
        • 803
        Actually TP motors numbering makes the most sense. 40XX = the length of the rotor. 4050 is a 50mm rotor.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • larryrose11
          • Jun 2010
          • 757
          Going with the stock motor mount means that there is space under the motor that you can put a relatively flat ESC, like Etti or Swordfish.
          • HTVboats
            • Jun 2011
            • 803
            Or you can move the motor to the rear with a shorten driveline (less friction) and put battery up front with ESC in between (shorter wires). I used the JAE tub made my own motor mount out of plate in kit and built sponsons similar to KEPs
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • sammyha
              • Jul 2018
              • 1038
              Mic[ATTACH=CONFIG]171185[/ATTACH]
              [ATTACH=CONFIG]171186[/ATTACH]
              [ATTACH=CONFIG]171187[/ATTACH]
              Interesting layout, and similar to a layout I thought of doing...
              • sammyha
                • Jul 2018
                • 1038
                Well, I've made my decision on the motor mount. I'm going with the OSE mount with rear support. I'm setting it at the same angle as the stock mount and locating the motor in the stock position in the tub. The ESC will fit in front of the motor.
                This also means I can use the pre-bent stuffing tube I bought with no mods to the former it goes thru or to the laser cut hole in the floor.
                • sammyha
                  • Jul 2018
                  • 1038
                  I'll also have full range to move the batteries for CG adjustments.
                  • sammyha
                    • Jul 2018
                    • 1038
                    Here's a modification I did to lower the battery tray. I'll roll some pictures, let them tell the story. Those are 5,000mah 3 cell lipos btw...
                    • sammyha
                      • Jul 2018
                      • 1038
                      A pair of 5000mah, 4s Revolectrix...
                      • ezhitz
                        • Aug 2009
                        • 428
                        I built the fe 33 as per the instructions except I?m running a tp4060 1650kv with a single 6s 4400mah. I just made the battery hatch with a hump.
                        :canada
                        • sammyha
                          • Jul 2018
                          • 1038
                          #27
                          [QUOTE=ezhitz;750342]I built the fe 33 as per the instructions except I?m running a tp4060 1650kv with a single 6s 4400mah. I just made the battery hatch with a hump.
                          I guess that works.
                          No offense meant, but it would be painful for me to do that...
                          Your rigger runs nice. Did you hit something in that video?
                          • sammyha
                            • Jul 2018
                            • 1038
                            #28
                            I'm sticking some wood together with epoxy. The build begins...
                            • sammyha
                              • Jul 2018
                              • 1038
                              #29
                              Here's the tub built and weighted while the epoxy cures.
                              Second one is a picture of a nice straight and square tub...
                              • sammyha
                                • Jul 2018
                                • 1038
                                #30
                                Here's how I filled the slots for the stock motor mount(that I'm not using).
                                I cut pieces from a parts sheet that had the laser burns on it. This gives me the option to leave the tub natural and just clear coat it.
                                Instead of seeing epoxy, or wood filler, it looks like the end of a former...
