fantasm 41 build
I just ran my Titan after sealing putting sealant on the hardware. Not a drop now . During my previous testing runs it consistently had less than a ounce of water. Not a drop in 2 runs !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Just ran in the pond by my house and the lvc setting fixed the esc problem. i did 54.1 mph on the gps with 447 props. temps were 105 motors , 110 batteries, 115 esc's and the caps on esc's were 145 . is that hot for the caps and what should they be? still got alot of water in my boat just like before about 1/4 cup or so. when you guys do hardware do you cover the entire piece of hardware with silicon and then just wipe excess clean after installation? or do you fill the holes and screws only and then install hardware?Comment
I'm pretty sure your batts aren't throwing enough amps, that makes the caps work too hard."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Honestly, there's never really been the need tho.
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
I would just put a little where the screws went in.
Just ran in the pond by my house and the lvc setting fixed the esc problem. i did 54.1 mph on the gps with 447 props. temps were 105 motors , 110 batteries, 115 esc's and the caps on esc's were 145 . is that hot for the caps and what should they be? still got alot of water in my boat just like before about 1/4 cup or so. when you guys do hardware do you cover the entire piece of hardware with silicon and then just wipe excess clean after installation? or do you fill the holes and screws only and then install hardware?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I am a honda bond 4 user ! Get it right lol great stuff . It is a little over kill for our applications but it will work the best, just used some on my T29. I like LAaC plumber putty idea, much easier to clean up the surface should you have to pull hardware ."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
I have the same boat and also have the scale rudder with the push pull set up. I find that water is coming in the boat between the turn cables and the sleeves. I now put some heat shrink around the area where the cable protrudes out of the sleeve, plus I now fill the sleeves with corrosion x before each run and now it doesn't leak much at allComment
