I guess I will be resurrecting a classic.
I am picking up the hull tomorrow afternoon. This will be a slow build since I'll be getting the parts bit by bit.
I am going for a very clean build. Being pretty is a big thing for me. Wires will be as short as possible and wrapped. Everything will color match. I'll be using anodized fasteners.
This is also my first non micro build.
Intended setup:
XK3674-B-2200kv 4 pole (need)
Turnigy Marine 120A (need)
2S 3600mah 30-40C (x2 in series)
X442 CNC Prop (need)
Final Setup:
GForce 3660 2200kv 4 pole
Turning Marine 120A
2S 3600mAh 30C x2 in series
Some suitable servo from HK...
40mm and 45mm plastic test props, 1.4 pitch
Hardware:
UL-1 Rudder and Strut
Octura .150" Flex Shaft with Liner to 3/16" Shaft
...Coupler
Octura Brass Bullet
5.5mm Bullet Connectors everywhere
Intended setup:
Final Setup:
Turning Marine 120A
Hardware:
...Coupler
Octura Brass Bullet
