Where is the water actually coming in to the boat ?
21 inch bby oval racer build
You might need to re-apply grease to your shaft. Depending on how much water is coming into the boat though, you might have the wrong sized shaft installedCome to the FASST sideComment
If its only a drop or two every ten seconds it should fixable if you just apply some grease to your shaft, it will help.Come to the FASST sideComment
Not sure, I use the grim racer speed grease from OSE. I dont see why you could'nt use other greases though.Come to the FASST sideComment
Do or do not, there is no try!!!!!
Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)Comment
The grease that you have should work fine. You might find though that it will thin out rather quickly, so it may need to be reapplied more often.Come to the FASST sideComment
ok total price count-up!
115$ for hull
8$ for the peice of metal for moter mount
5$ for the scrap metal for turn fins
3$ for the bracket mounts for the turn fins
23$ for prop and flex shaft
17$ for custom stinger
appx 31$ for the scraps of metal for the custom rudder and mount
15$ for the custom cf steering rod
9$ for the scraps of metal to make the trim tabs
appx 36$ for the pvc tube, plywood, tmaxx a arms, and rc18t wheels for stand
23$ for red and black paint and clear coat
appx 10$ for the spectrum servo
17$ for the aluminum and brass tubes
10$ for 5 feet of high flow tubing
appx 100$ for all the electrics
15$ for all the balsa wood
95$ for the spectrum reciever
15$ for a huge container of lithium grease
my wallet is
a nice racer boat = pricelessLast edited by phase; 03-14-2010, 10:29 PM.Comment
