    • 7673
    #1261
    Sooo,which one is quicker?
    • masonis1
      If you cant control it 👍👍
      • 1173
      #1262
      Well out of the line mine is. It doesn't cavitate near as much. Right up on plane compared to.about 15 feet for the blast. But the blast rides flat at full throttle where mine bounces... A lot. The blast is faster but can't turn the nose dives down.and the.boat goes under after any semi.hard turn. Mine handles better.and accelerates.better but.I need to.keep it from.bouncing.
      Sent from my SPH-D700 using Tapatalk 2
        • 7673
        #1263
        It can be tricky with a mono.My DF 35" is still not dialed in.
        • masonis1
          • 1173
          #1264
          So where can I start? weight movement or strut movement
          • masonis1
            • 1173
            #1265
            The t180 is as cold as it was when I put it in afterm running full throttle for 15 minutes straight.
              • 7673
              #1266
              Do you have a current side pic of the strut.It should be parrallel with the hull.Run a ruler down it and see.You would be surprised what a difference a degree would make.
              • masonis1
                • 1173
                #1267
                Ok. It does seem to be at a downward angle.
                  • 7673
                  #1268
                  That'll make her bounce.
                  • masonis1
                    • 1173
                    #1269
                    Should it be straightbwoth the transom straight with a flat surface on the ground?
                    • masonis1
                      • 1173
                      #1270
                      I have it as flats it possible can get. Ill test it. Wb weight?
                      • masonis1
                        • 1173
                        #1271
                        Hey, havent talked in here for a while. Remember that blast i.wanted to.beat. Here it is with almost same setup. https://www.youtube.com/watch?v=Tqfa...e_gdata_player
                        • masonis1
                          • 1173
                          #1272
                          Ok so I did some work because a new build is restarting me that I saw. I want to help him.
                          So still running a turnigy 2700 bl motor
                          Now a turnigy 60a esc,
                          I'll do a 2s test and 3s test coming up. I also did some work to help the boat ride better an to accept a new prop.
                          Yes that's the miss geico prop
                          Lipos being tested
                          • Make-a-Wake
                            FE Rules!
                            • 5557
                            #1273
                            First of all, awesome river to run in.........Beautiful!!
                            Secondly, that Blast runs well, all it needs is about 2-3mm more in prop diameter and its a ripper!
                            • masonis1
                              • 1173
                              #1274
                              Thanks, and how do you think this prop will do on this boat?
                              • Make-a-Wake
                                FE Rules!
                                • 5557
                                #1275
                                What prop?
