32" hotr 90+mph
This topic is closed.
  • Howard Lee
    • Nov 2010
    • 198
    #391
    I got out for a test run this morning. I thought i would give this new prop a try. I still need to work on it. I'm running the same drive shaft that the motor mount broke loose with (its off balance). I needed to see how this prop handles the top speed before i replace it, i don't want a high speed flip to do the same thing to the new shaft. I have a vid, its not great but ill give you a little something to watch.
    • Howard Lee
      • Nov 2010
      • 198
      #392
      http://www.youtube.com/watch?v=
      • keithbradley
        • 3663
        #393
        Nice.
        What are you using for nuts with those hatch screws?
        www.keithbradleyboats.com
        • Howard Lee
          • Nov 2010
          • 198
          #394
          Nice.
          Check kintecracing http://kintecracing.com/Nuts___Bolts.html The hatch bolts are short for this setup but t-nuts work good.
          • Howard Lee
            • Nov 2010
            • 198
            #395
            I have a vid of my genesis but no gps. Forgot to hit start but looks very fast. Check out the trees blowing around, its a very windy day. http://www.youtube.com/watch?v=
            • martno1fan
              Banned
              • Jan 2011
              • 238
              #396
              Very nice runs,can i ask what setup your using in the Genesis cat.Im in the process of making a plug for a similar type cat based on the mystic cats shes 38" long and im not sure what setup to go with when i get one built,i was considering the Turnigy 3648 1450 kv motor on 4-6 s maybe the t 600 on 6 s .Could also go with twins.
              http://www.hobbyking.com/hobbyking/s...idProduct=8485
              • Howard Lee
                • Nov 2010
                • 198
                #397
                Originally posted by Martinson
                Very nice runs,can i ask what setup your using in the Genesis cat.I'm in the process of making a plug for a similar type cat based on the mystic cats shes 38" long and I'm not sure what setup to go with when i get one built,i was considering the Turnigy 3648 1450 kV motor on 4-6 s maybe the t 600 on 6 s .Could also go with twins.
                In my genesis and 32 i have the same setup. Leopard 4082 1500kv on 9S and i run a s/f 240HV. I'm not into outrunner motors, I think water cooled is the way to go in a sealed compartment. It all really comes down to fast you want to go. I like 1 motor in a small cat. Its hard to get your setting just right and another motor just adds to it. You might say its double the trouble, not trying to offend anyone. If there is anything i can help you with just ask.
                • ray schrauwen
                  • 9471
                  #398
                  That outrunner is far from the quality you want for a speed runner. It says only 70 amps max for 20 seconds... not good, Poof!
                  The Suppo type outrunners that Fightercat sells far surpass those motors. HK also sells some Suppo outrunners.
                  I like the Turnigy Trackstar 4068, 2560Kv, 6 pole motor, 2200watts.
                  I have one on the way this week to drop into Miss G for speed runs....
                  Beauty motor!!!
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    #399
                    Howard;
                    can you please take a couple of pictures of the inside of your 37" genesis?
                    I gotr oneof Bens 37" Daytona hulls and will be running a 1760KV suppo on either 8 or 10S.
                    Just waiting on the new HV ESC's he is going to be carrying to arrive.
                    thanks much
                    Carl
                    [email protected]
                    getting ready to launch the twin FE 45" Insane mono conversion on its; maiden voyage next saturday if the weather cooperates here in the N. VA area.
                    • Howard Lee
                      • Nov 2010
                      • 198
                      #400
                      Originally posted by carlcisneros
                      Howard;
                      thanks much
                      Carl
                      [email protected]
                      Very nice setup. My genesis looks like my 32. I don't have any pics but i will take some next time i take it out. I'm going to spent a little time setting up my genesis/37 to see just how fast i can go with a 40 leo. Your build looks good and if you need help just ask.
                      • martno1fan
                        Banned
                        • Jan 2011
                        • 238
                        #401
                        Yea think ill go with the t 600 1100 or 1400 kv motor on 5s 2p maybe 6s which one would be best.Not looking to do 90 mph anywhere over 50-55 would do me.
                        http://www.hobbyking.com/hobbyking/s...dProduct=11980
                        • 6sHyper
                          <<<Surfs up!
                          • Jan 2011
                          • 597
                          #402
                          hey man, my friend here had that same motor in his genesis and it was a slug, it begged for 6s2p and speeds were not very good, 45mph and run times were short. I would NOT suggest that T600 in a single genesis if your looking for speed, but hey if your just looking for a reliable short time runs at 45mph its perfect cause it doesn't get hot at all. keep in mind it needs every bit of 6s though.
                          • martno1fan
                            Banned
                            • Jan 2011
                            • 238
                            #403
                            Beauty motor!!!
                            That trackstar motor looks interesting ,im not looking for record speeds just fast and reliable,i have 2 6s lipos 30c 500mah and a hk 190-200 esc sat doing nothing what speeds would you think i could get with that setup and what prop.
                            • Jacked1
                              • Jun 2010
                              • 772
                              #404
                              Howard, Have you considered using a castle 1717 on your Genesis to see if you can push it over 100 as well? I have not seen a higher voltage setup with one yet.
                              Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
                              • keithbradley
                                • 3663
                                #405
                                I've ran one over 100mph on 9s.
                                Not in a boat though
