BBY's HRP 06 build
  • JCAustralia
    • Jul 2008
    • 304
    #46
    Amazing build Randy.
    Love the tank oiler! Very curious to see how it works at the end.
    • Rumdog
      • 6453
      #47
      That thing is going to SCREAM!
      • RandyatBBY
        • Sep 2007
        • 3915
        #48
        Little up date I am almost done, a few little things to do. waiting for the Hisol to dry for the hatch latches mounts
        Uploaded with ImageShack.us
        Randy
        BBY Racing
        • RandyatBBY
          • Sep 2007
          • 3915
          #49
          Randy
          BBY Racing
          • JohnZ
            • May 2010
            • 254
            #50
            Randy, What battery packs are you using? Where do you get them?
            Looks like a real screamer. Hope you get it wet soon.
            • RandyatBBY
              • Sep 2007
              • 3915
              #51
              They are the ones I sell "RC Polly" Great cells. First test run today with tiny props X442 at Heather Farms Park.
              Randy
              BBY Racing
              • Hpr115uk
                • Sep 2010
                • 15
                #52
                For a good , permanent , neat , heat resistant bond I have tried and had success with. . . 3m dp490 . It's black !
                • vvviivvv
                  • May 2009
                  • 1091
                  #53
                  could you post some pics of the boat's battery mounts and with a ruler on top so i can see roughly where the motors are mounted + the battery's... i haven't even looked inside my hpr115 in 2 months i couldn't get it to break plane last time i had it out (2nd run) it has the cg all wrong and made a massive bow wave... like bigger than a 2 meter long heavy tug...
                  also, could you post some pics of how your hatch lock system works and where to get them? cheers.
                  Uk SAW record holder
                  • westbeach
                    OSE Rocks!
                    • 951
                    #54
                    Liam, problems with the boat? Take a picture of the inside. So we can diagnose for you.
                    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
                    • vvviivvv
                      • May 2009
                      • 1091
                      #55
                      Hi it is Neal yes? Been som time... I will post 1 or 2 if randy doesn't mind later... One of my problems was the props where angled too high well for how I had the weight set out... Annother is where to place the batteries my motors are 9.8cm back from the opening of the rear hatch...
                      However the one good bit of news was that while the boat was on full power for 10 seconds trying to l
                      Plane it drew less than 60 amps... With 45mm 3 blade 1.8 pitch... I think I need to try my 47mm 2 bladders... Might have to post when I get back from 6 form
                      • RandyatBBY
                        • Sep 2007
                        • 3915
                        #56
                        I do not mind if you take up my slack. Cool Beans! We ran the boat a week ago. The efficiency of the drag on the bottom is amazing the 06 runs like a SAW boat! I set up the CG between 25% to 30%. We ran close to 60MPH on 442's.
                        Randy
                        BBY Racing
                        • vvviivvv
                          • May 2009
                          • 1091
                          #57
                          wow this website is slow nowadays...
                          my boat must be real heavy or my cg is way too back probs the cg considering i aint got a clue what it is ... 45 3 blade props couldn't manage to get it planing
                          could i see some pics of your hatch locks up close?
                          also how far down are people angeling the drives? mine where slightly up from flush with the bottom of the boat... but when i think of our full size boat to make it plane better we angle the drive units down then trim up to get to the top speed... how far down should i drop mine?
                          • vvviivvv
                            • May 2009
                            • 1091
                            #58
                            Maybe i need bigger motors(?) i seen them run on 8xl's at 70mph... argh this is why i kinda hid the boat and just left it
                            • RandyatBBY
                              • Sep 2007
                              • 3915
                              #59
                              In this boat I am running a 1527 .5Y on 4S2P each on a 442 left and right. The boat ran for about 6 passes safely with a 240LV Hydra.
                              Randy
                              BBY Racing
                              • westbeach
                                OSE Rocks!
                                • 951
                                #60
                                Liam, What wind is the Neu 1521's? Or how many KV. And what are the specs of your lipos? 4S, 5S or 6S or bigger? How much Mah's?
