could you post some pics of the boat's battery mounts and with a ruler on top so i can see roughly where the motors are mounted + the battery's... i haven't even looked inside my hpr115 in 2 months i couldn't get it to break plane last time i had it out (2nd run) it has the cg all wrong and made a massive bow wave... like bigger than a 2 meter long heavy tug...
also, could you post some pics of how your hatch lock system works and where to get them? cheers.
Liam, problems with the boat? Take a picture of the inside. So we can diagnose for you.
HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
Hi it is Neal yes? Been som time... I will post 1 or 2 if randy doesn't mind later... One of my problems was the props where angled too high well for how I had the weight set out... Annother is where to place the batteries my motors are 9.8cm back from the opening of the rear hatch...
However the one good bit of news was that while the boat was on full power for 10 seconds trying to l
Plane it drew less than 60 amps... With 45mm 3 blade 1.8 pitch... I think I need to try my 47mm 2 bladders... Might have to post when I get back from 6 form
I do not mind if you take up my slack. Cool Beans! We ran the boat a week ago. The efficiency of the drag on the bottom is amazing the 06 runs like a SAW boat! I set up the CG between 25% to 30%. We ran close to 60MPH on 442's.
Randy
For ABS, Fiberglass, Carbon hulls and Stainless hardware BBY Racing
my boat must be real heavy or my cg is way too back probs the cg considering i aint got a clue what it is ... 45 3 blade props couldn't manage to get it planing
could i see some pics of your hatch locks up close?
also how far down are people angeling the drives? mine where slightly up from flush with the bottom of the boat... but when i think of our full size boat to make it plane better we angle the drive units down then trim up to get to the top speed... how far down should i drop mine?
Uk SAW record holder
