BBY's HRP 06 build
randy i'm thinking the lower we can mount these batteries the more stable the boat will be ,your thoughtsComment
Randy .
You know that the closer the struts are towards the tunnel, the better it is ?
You might even need to remove material from the inside of the hull to be able to fix the struts in place.Comment
I actually put the struts real tight to the center of the hull. I will show a picture later today.Comment
I have the rudder installed only took 2.5 hours to get 4 bolts & nuts in place.Comment
well its a high end titanium geared servo and i wanted to put it to use .since i already own it . though i agree with keeping the wieght low in the haul . thanks for your thoughtsComment
For the water pick ups Damon was told that for the best adhesive to marry aluminum to fiberglass is Hi Sol. Any one have any info. I will be getting something on Monday for the pick ups.Comment
