King Of Shaves C1 Brushless!
  • Igoreski
    • Apr 2010
    • 77
    #496
    Hotr
    I keep hearing about HOTR cats,where do they come from.
    • Tuslow1
      • 154
      #497
      They come from Hong Kong but you can get 'em on ebay....
      OK, You Go First!!!
      • Tuslow1
        • 154
        #498
        BTW if you have a few spare days to do nothing but read the HOTR thread has almost 30 pages of info, setups, pictures and videos for you to enjoy and take notes from. I think it's the biggest thread in this forum. Get the hull from them and OSE has the rest of the parts to make it scream out LOUD!!! http://forums.offshoreelectrics.com/...ead.php?t=5487
        OK, You Go First!!!
        • Igoreski
          • Apr 2010
          • 77
          #499
          Great info.
          Thanks
          • C-Mac
            • Apr 2010
            • 39
            #500
            Is there a Feigao brushless, in the L size, that will give good top speeds and run well on 120A ESC's and 3-4S lipos?
              • 9479
              #501
              I would stay with the XLs
              • C-Mac
                • Apr 2010
                • 39
                #502
                Thanks Brushless55. XL's it is :)
                • Wakesurf1
                  • Apr 2010
                  • 9
                  #503
                  What are the pros and cons of running the 10xl instead of the 9xl? It looks like they have plenty of the 10xls in stock. I'm running 4s with 442s on the stock ESCs (until they blow that is!!). Thanks in advance!
                  • forescott
                    Hopelessly Addicted to RC
                    • 2686
                    #504
                    10xl's will probably do really well with the 442's I bet in the low 50's.
                    • Wakesurf1
                      • Apr 2010
                      • 9
                      #505
                      Great! Thanks for the info.
                        • 9479
                        #506
                        also, they will take 4s much better than the 9XLs
                        • VIKOS
                          • Jan 2010
                          • 204
                          #507
                          ok so this week I'm ordering from rcraceboat.com now do I really need to run a flex shaft tube won't it sitting in the strut with all the marine grease just be fine...did this with the last shafts and had no problems...its those damn couplers and yes I will me getting those too...if I need the tubes I'll order them from venom but if they don't fit then whats the point then...?
                          • Igoreski
                            • Apr 2010
                            • 77
                            #508
                            Flex shafts.
                            Here is what I used.Go to your hobby shop and get Sullivan #511 red teflon tube.You might have to buy the kit for $6 but it comes with lots of other stuff you might need down the line.The size is perfect for the HD flex shafts as the stock ones are tight on the new shafts and cause some binding.
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              #509
                              I have new stuffing tubes that will go with the newer cables. The stock cables should have more room in them but they don't. The slightly larger cables ARE a little too tight for the older stuffing tubes.
                              Something I am loading up on the web this evening is wiredrives and couplers for the EKOS. No need to change stuffing tubes and they will run better than cables. No L/R cable crap. 2 wiredrives and two couplers is all. If you like wiredrives then this would be the setup that should rock.
                              The better couplers are the key to either setup.
                              www.rcraceboat.com
                              [email protected]
                              • C-Mac
                                • Apr 2010
                                • 39
                                #510
                                Finally got my EKOS on the water today after sticking in some 10XL's and Seaking 120A ESC's. I ran graupner cf-40's and topped out at 70.7 kph ( about 44mph) in not the best conditions. Sure was nice to run the boat with no issues, nothing but smiles. I think I will try some X442's. Big thanks too all on the forum for the help and info, Steven from OSE and Venom for making a sweet looking hull.
