I feel your pain mate. Took mine for a run last weekend & lost a flex shaft in 4m of water. This has been the most expensive rc i have ever had with the least amount of run time & to top it off 1 of my Turnigy packs has puffed up after 2 uses & H/K won't replace it. I have sent them pics & the postal service won't take it because it could blow up, so i don't get any help off them because they want it back.
King Of Shaves C1 Brushless!
stock motors for now, thinking of running fiego later....dont mess with it??? guy that programmed esc again had issue hearing the left esc during program....kinda has me spooked because when i purchaced the boat used the left engine was falling off line during bench tests .......lost program somehow but is online again now and set for 2s for 4 totalComment
Leopard or Tacon 4 pole motors would be nicer than Feigao's in this. They have nice ones in 28mm x 60mm.
I have a pair of 5050 kv's for a Drifter S build. They also have 2550 kv @ hobbypartz.com either are about $46 each on sale. 1200 watts each. Check Feigao specs for their 380xl motors, 1/2 the watts or so only....Nortavlag Bulc
Feigao:
This 380xl Sized Feigao Motor is 67mm in Length.
Motor Specs:
4-8 NiMH or 2s to 3s Lipo cells in a Mini monos or Mini hydros in the 17-22" or so range.
440 Watts Maximum with proper cooling.
27.6mm dia x 67mm long
1/8" OutPut Shaft
7.2 Ounces
Aluminum Purple Anodized Casing
2-Pole Neo Magnets & Compressed Windings
Motor mount screw spacing is both 16mm and 19mm.
3mm motor mounting screws.
OSE recommended rpm range of 17,000 to 35,000
Leopard:Nortavlag Bulc
