I just got 2 .187 drive cables from Jeff wholt , they are alittle bigger i'n diameter than the stock, which I knew... But I heard i'n here someone mentioned to take the Teflon liner out and it'll fit? Along with using quite a bit if speed grease? Thoughts?
Spartan .187 drive cable
Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Tags: None -
Sorry Jeff wohlt.... Spelled the last name wrong... LolScott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull.... -
Yep, that's the ticket.
The nice thing about the Spartan is, if you do wear through the stuffing tube over time, it is inexpensive and easy to replace because it isn't glued into the hull.
KevinComment
True thts what I figured already have one extra..... Just waiting on some hardware and some wire & connectors and I should be able to finish building the thing...the only other thing I might do is use 4 ,4000 mah turnigy lipos i'n series/ parallel but well see may be alittle heavy.... But not to concerned about it.... Although boats being heavy are slot different than a car being heavy.... LolScott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
There is a school of thought that a little extra weight might help stabilize this boat.True thts what I figured already have one extra..... Just waiting on some hardware and some wire & connectors and I should be able to finish building the thing...the only other thing I might do is use 4 ,4000 mah turnigy lipos i'n series/ parallel but well see may be alittle heavy.... But not to concerned about it.... Although boats being heavy are slot different than a car being heavy.... Lol
It would likely cost you a bit of top end speed, but if you are looking for longer run times and stability, rather than breaking speed records, it might be a good set up.
I'm going to try the same when we finally get some liquid water around here.
KevinComment
Yeah I hear ya... I'm gonna experiment too and see wt works best...Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
o..std is 150 so 187 needs a new coupler. More cable coming today...was out of 150. An 078 wire does very well on these also.VComment
I think I would try it on stock liner. Most of that is metric so hard to fit new stuff.Comment
Hi Jeff Wohlt I have a question , I receive the 150 drive cable from you , but is thinner then the stock cable that came with the spartan , is that normal ? also is loose inside the liner do i need another liner that will accommodate the new cable ,
thanks in advance .
Nope...run it as is. I think the Octura cable is stronger. 150 is actually about 147.Comment
That is interesting.
Checking the Spartan flex cable with a caliper three or four places along the length it is dialing in at a true .150 - .151 diameter. (3.82mm).
Not that 3 one thousandths is very significant on a flex cable.
KevinComment
