Spartan .187 drive cable
  • Rcforever27
    • 240
    I just got 2 .187 drive cables from Jeff wholt , they are alittle bigger i'n diameter than the stock, which I knew... But I heard i'n here someone mentioned to take the Teflon liner out and it'll fit? Along with using quite a bit if speed grease? Thoughts?
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
  • Rcforever27
    • 240
    Sorry Jeff wohlt.... Spelled the last name wrong... Lol
    • dag-nabit
      • Feb 2011
      • 775
      Yep, that's the ticket.
      The nice thing about the Spartan is, if you do wear through the stuffing tube over time, it is inexpensive and easy to replace because it isn't glued into the hull.
      Kevin
      • Rcforever27
        • 240
        True thts what I figured already have one extra..... Just waiting on some hardware and some wire & connectors and I should be able to finish building the thing...the only other thing I might do is use 4 ,4000 mah turnigy lipos i'n series/ parallel but well see may be alittle heavy.... But not to concerned about it.... Although boats being heavy are slot different than a car being heavy.... Lol
        • dag-nabit
          • Feb 2011
          • 775
          There is a school of thought that a little extra weight might help stabilize this boat.
          It would likely cost you a bit of top end speed, but if you are looking for longer run times and stability, rather than breaking speed records, it might be a good set up.
          I'm going to try the same when we finally get some liquid water around here.
          Kevin
          • Rcforever27
            • 240
            Yeah I hear ya... I'm gonna experiment too and see wt works best...
            • wilsta67
              • Feb 2011
              • 203
              with the 187 cable can you use the std Colet ?
              • dag-nabit
                • Feb 2011
                • 775
                I can't see it would fit, I'm pretty certain a new Collet will be necessary. 5mm motor shaft to .187 flex.
                Kevin
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  o..std is 150 so 187 needs a new coupler. More cable coming today...was out of 150. An 078 wire does very well on these also.V
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • dag-nabit
                    • Feb 2011
                    • 775
                    Jeff,
                    When going to the wire drive do you need to change anything on the stuffing tube?
                    New tube?? or different liner??
                    Thanks
                    Kevin
                    • Jeff Wohlt
                      • Jan 2008
                      • 2716
                      I think I would try it on stock liner. Most of that is metric so hard to fit new stuff.
                      www.rcraceboat.com
                      • mavdriver
                        • Dec 2010
                        • 65
                        Hi Jeff Wohlt I have a question , I receive the 150 drive cable from you , but is thinner then the stock cable that came with the spartan , is that normal ? also is loose inside the liner do i need another liner that will accommodate the new cable , thanks in advance .
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          Nope...run it as is. I think the Octura cable is stronger. 150 is actually about 147.
                          www.rcraceboat.com
                          • mavdriver
                            • Dec 2010
                            • 65
                            Ok will do thanks for the response .
                            • dag-nabit
                              • Feb 2011
                              • 775
                              That is interesting.
                              Checking the Spartan flex cable with a caliper three or four places along the length it is dialing in at a true .150 - .151 diameter. (3.82mm).
                              Not that 3 one thousandths is very significant on a flex cable.
                              Kevin
