Your MG that started off as a hull
  • HYDROJERRY
    • Jan 2010
    • 2503
    #1936
    And just wanted to show how easy it would be do make a standoff for your gear, i did this in about 15min last night on my Genesis,, first removed the rudder, had some long bolts so i drilled out the bolt holes that connected the rudder to the strut,, took a short measurement then found some tubeing just bigger then the bolts, cut them down the put the long bolts threw the strut bracket then slipped the tubeing over them then put on the rudder and nuts and here you have it!PS everybody loves pics..
    • lenny
      • Sep 2010
      • 4293
      #1937
      Yes it is,
      And they work great for soldering the bullet and anything else.
      Shrink wrap to, Just not to close to it,
      Also very cheap and portable to.
      ? ONLY IF THEY WORK
      • HYDROJERRY
        • Jan 2010
        • 2503
        #1938
        Lenny dosent that thing char your parts thow??? Great price thow..think i paid like 35.00 for mine.
        • lenny
          • Sep 2010
          • 4293
          #1939
          No, Just a little flux resin that can be cleaned up if you want.
          Lowe's has them to pretty cheap.
          ? ONLY IF THEY WORK
          • lenny
            • Sep 2010
            • 4293
            #1940
            Nice 4x4 toys.
            I will get one some day.
            ? ONLY IF THEY WORK
            • HYDROJERRY
              • Jan 2010
              • 2503
              #1941
              I may get one to do my heatshreink,, thanks, i gotta have something to play with when i cant get the boats wet but here lately i havent had much time for anything,, o well thats life..
              • macdon
                • Jun 2011
                • 970
                #1942
                Wow! We are at page 65 already? hahaha!
                Gotta go boating now - see you guys later!
                • skyman
                  • May 2012
                  • 290
                  #1943
                  Have fun! Lucky you!
                  Sent via Tapatalk
                  Axial Yeti XL - Traxxas Slash 4x4 (x2) - Losi Mini 8ight - Tacon Soar Buggy - Blade 120SR - Miss Geico 29 (hull + parts)
                  • skyman
                    • May 2012
                    • 290
                    #1944
                    Are those Jconcepts bodies? You have very good taste buddy. I'm on my phone, I will respond a little later.
                    Sent via Tapatalk
                    • skyman
                      • May 2012
                      • 290
                      #1945
                      OK some pics,, to start this my Weller soldering gun i use, then you have my slash with the new 1/8 truggy wheels..
                      i love the tray in pic#1
                      • skyman
                        • May 2012
                        • 290
                        #1946
                        Miss Geico Hull Has Arrived!
                        look at what came today
                        there's no looking back now....
                        • jasoncyclone
                          • Jun 2011
                          • 475
                          #1947
                          Nice!!!! Now finish the build and get her on the water!!!! Just kidding.. Take your time and do it right. You should blueprint the sponsons. Mine were cupped badly. Have you read about blueprinting the ride surfaces?
                          Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
                          • skyman
                            • May 2012
                            • 290
                            #1948
                            honestly, i have no idea what blueprinting is. first time i heard it was when shawn mentioned it. no i have not read about blueprinting ride surfaces.
                            • jasoncyclone
                              • Jun 2011
                              • 475
                              #1949
                              If you do a search for blueprinting you will find a detailed thread about what I'm talking about. Basically you flip the boat over and take a nice flat sanding surface 12 inch minimum length, and start lightly sanding the bottom of the sponsons to get them perfectly flat. You will find that the ride surface is not flat we call this "hooks". After sanding a little you will find that you will need some glazing putty for the low spots. After the putty is dry, you sand again. Keep doing this until the ride pads are nice and flat. If you do this, you should do more reading up to make yourself familiar with the process. This will make the boat faster and alot more consistent when driving!
                              • jasoncyclone
                                • Jun 2011
                                • 475
                                #1950
                                I also you a small torch to do my soldering...
