Miss Geico Lets see what this thing can do!
Jack, it is impossible for you to not lose speed in a turn with the inline setup... The rudder is in direct interference with the natural cone of the prop. Whether or not it's a big difference is the issue but I can guarantee you you'll losing some speed.. hence why the larger counterparts typically have dual rudders or engines on the outside of the rudder... its not only more stability, its to maintain the speed through a course.Comment
I noticed a HUGE difference while cornering during races when I went to the offset rudder. Running the boat by myself, I never realized how much it was actually slowing until I started racing it. I was blown away how much it slowed down. I did find, and posted somewhere... I think in the race set up thread, that offsetting it has nothing to do w/ getting rid of the bounce. Its all about finding the trim and balance. JackB already said that. Anyway, If I wasnt racing, I probably would have kept it inline just because I prefer the look.Comment
Heck Ive even tried to tune it to bounce and I cant with the bracket on..Comment
Filled in my rudder inlet since it's not used now.
Also took the rudder brace off and finished it up. Made an epoxy block on the inside of the transom where it mounts so it's more securely attached and solid to the boat/hull. Before I was pressed for time wanting to go run again I used an aluminum brace I cut and made. But wasn't 100% happy with how it held. Also sealed the bracket to the hull with rtv as I mounted it. Instead of the thin rubber pad I was going to use.
Land, Sea & Air, A true RC Addict.Comment
So again, for me, my setup works just fine :)Comment
I've got 4 with the girl and flags being made up(see last post with it superimposed on my boat) to see how it's going to go. They were supposed to be done today but they haven't finished them yet. I might get them Thursday or Friday.Land, Sea & Air, A true RC Addict.Comment
Got to run a little today after work. The offset rudder helps a bunch. I still need to play with the setup to keep the boat on the water. I have the COG way forward like 12" and the strut level all around. Still can't hold throttle down or she will blow over. I was able to get her up to 59.8 MPH today tho. Still has more than that locked away. Might try a hair negative strut angle or make a clear lexan air dam. Just kicking ideas around for now.Last edited by JPriami; 04-25-2011, 11:56 PM.Land, Sea & Air, A true RC Addict.Comment
where is the strut set at? tiegman is running his level and touching the top of the table when boat is sitting on table......may have to shave the cornner off the strut brace with a big propMY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
My props won't ever hit the strut brace now. I've cut some length off it since I made a new offset rudder mount.
Might be able to see how much I cut off in this pic. the two bolts on the back of the brace have been relocated I drilled those holes out for them to mount there.
I have the strut dead level with the bottom of the hull. Center of prop shaft is at same level as bottom of ride pads. The angle is set at 0.Last edited by JPriami; 04-29-2011, 07:23 PM.Land, Sea & Air, A true RC Addict.Comment
