''O'' my bad..
Miss Geico Lets see what this thing can do!
Strut looks to high i think,,take off the prop and sit it on the table loosen your strut push the strut down flat on the table with the hull stting flat on the table and tighten it,,,and if your strut wont go that far down grind the hole in the strut to make it long ways up and down then you can adjust it down,,i run mine with my batts level with the front edge of the battery trays ,,hope this helps..Comment
Try a m445 I run it on mine with just about the same setupSocal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180Comment
Just watched your back view video there 26missgeico. That was neat. Camera does pretty well in low light conditions. Is that a GoPro HD hero or reg GoPro?
What new esc did you get? What setup are you running now.Land, Sea & Air, A true RC Addict.Comment
J, are you just using the OSE "upgraded" MG flex shaft? How's it holding up?Comment
I should he getting my cc1515 2200kv motor and turnigy 180 esc soon!!! I can't wait to see what it will do in a MG. Any ideas on the prop I should be running? I was thinking a 642... Maybe a p220???Last edited by jasoncyclone; 09-14-2011, 09:52 AM.Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!Comment
