Miss Geico Lets see what this thing can do!
  • jasoncyclone
    • Jun 2011
    • 475
    #361
    I was planning on running 4S. Do you think I will get upper 40s with this setup? I don't need much faster than that.
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
    • JPriami
      N4FOX
      • 1675
      #362
      Yes you will do good with that setup. Prob in the 50's
      • CHIEFY_44
        • Nov 2010
        • 254
        #363
        I run 4s2p with a m445 runs great
        Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
        • 26missgeico
          • Aug 2011
          • 61
          #364
          i run a x645 it goes good
          • Blockhart
            • Jun 2011
            • 39
            #365
            JPriami,
            Was wondering how the dual water pick ups have been working for you? I've done a simular set up in my boat but haven't run it yet. I'm running a 4074 leo 2200 with seaking 180 4s2p and the caps were hitting 130 with the stock cooling. I'm hoping the new cooling set up with 4mm hose does the trick.
            Miss Geico?
            • JPriami
              N4FOX
              • 1675
              #366
              Well in the first miss geico I installed dual in hull pickups in each sponson. They seemed to cool but I hardly ever seen water coming out of the outlet.
              On the 2nd MG I used the rudder and a 2nd brass tube pickup. They seem to work well and I can see a flow of water.
              • Blockhart
                • Jun 2011
                • 39
                #367
                Shame, well hope I haven't made my problem worse. It's built now so will try it out and see.
                Miss Geico?
                • JPriami
                  N4FOX
                  • 1675
                  #368
                  Well I didn't seem to have any heat issues with those. Just didn't get the satisfaction/comfort of seeing much water exit the hull.
                  I'm faced with a similar problem with a twin cat I'm starting a build on now. I would love 4 pickups so there are separate pickups for 2 motors 2 esc's.
                  • Blockhart
                    • Jun 2011
                    • 39
                    #369
                    I did install an external BEC as well. Does that really make a big differance with heat? We shall see. The boat is crazy fast all ready. 1st trial run on 5s got 60.6mph. Have sence put more glass on the nose (flip and boom same as your vid), paint, carbon fiber inside, etc, etc. Just got to keep the temps down and a little tuning and might be able to touch 65mph. Boat runs best on 4s2p though. Happily in the 50's and plenty of run time. I've been running a p220 but have some others I'm going to try. Which prop has been your favorite? I'm Going to try to get some pics of the whole rebuild and maybe a run vid. Would like to give back to this site that as helped me out so much.
                    Miss Geico?
                    • JPriami
                      N4FOX
                      • 1675
                      #370
                      I run a separate RX pack and disconnect the ESC's + feed (BEC) to the receiver. Seems to get a hair more run time. But mostly I do it just for extra measure in hopes the esc wont have to work any harder than it has to since I run it on 6S at times.
                      • CHIEFY_44
                        • Nov 2010
                        • 254
                        #371
                        My caps regularly reach 130 even with a extra cap board but never had a problem, they do say an external bec does help bit remember to disable the onboard one, just remove the red wire from the esc plug and put heat shrink over it,do it this way and when you need to reprogram ur esc all u do is replace the pin into the plug, reprogram, remove wire again and ur done.
                        • JPriami
                          N4FOX
                          • 1675
                          #372
                          Well I finally took some time and made the rear mount for my 1518 in the MG. Plexiglass with a sprung wire loop that holds the back of the motor snugly in place now. Can be removed by a bolt to take motor out easily. Drilled holes in base of plexiglass and sanded it rough, then glassed the mount to the floor.
                          • maxmekker
                            • 412
                            #373
                            nIce looking. Mine is on the shelf, to cold here in Norway, ore well, if I had a resc. boat it would be fine,( 10c ore 50f) is to cold to swim, even for vikings :-) So I come here to see video's my friends, so keep'm comming. :-)
                            So as the cold set's in here in Norway, I play a little with my Merv (revo 1/16) and I just , after a week of blue screen and error codes , got my new rig up and running
                            ASUS Maximus IV GENE-Z - i5-2500K Processor - Corsair DDR3 1600MHz 8GB - MSI GeForce GTX 560Ti
                            So if anbody want a friendly fight, DL ' world of tanks ' and see you on the field :-)
                            Drammen rock City
                            • ecoovert
                              • Aug 2011
                              • 242
                              #374
                              I saw a major improvement with mine as well with my home made offset rudder bracket. By the way guys If anyone is interested I started a new group called North Carolina Fast Electrics. Anyone is welcome to the group. I do hope to atract other electric boat adicts from this neck of the woods. Y'all are welcome.
                              • ecoovert
                                • Aug 2011
                                • 242
                                #375
                                Hi there maxmekker. I use an inflatable raft. You usually can find them online for around $50 us. Heres a place that has the one I use. http://www.vminnovations.com/Product...-and-Pump.html I swim like a rock so I wear a life jacket. I used to use it when the temps were in the 40s and 50s when I lived just south of British Colombia in Bellingham, WA. You might give that a try. It might make you feel more like a viking.
