Oh, man. That really sucks. Were you in it? Hopefully you didnt have to swim too far.
Rafael Lopez
Product Developer-Pro Boat
My Facebook https://www.facebook.com/profile.php?id=100010183246751 -
Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Just the filter from editing. That's the fastest I've run the Zelos. You may notice the Voracity hasn't gotten much high speed runs and that's because quite frankly it's a bit unstable. When I get the cap bank I'll give it some adjustments and try again.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Hahaha... It's a Mono... by definition, they are "unstable"... :) Much easier to go fast when you can balance on two points, as opposed to just one point of a V.
Darin E. Jordan - Renton, WA
Yeah but in some of the videos you guys post it seems like it's riding on rails. Lol. Could be all that flat water you lucky bunch get.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Monos all have a designed "speed limit"... At some point you are going fast enough where most of the keel is out of the water, then bad things happen.
You combat that by adding weight, or redesigning the hull for a faster speed threshold.Darin E. Jordan - Renton, WA
Keagan, in your case I think it's just battery placement. That river is not as rough as the waters I tested the Voracity in. Try moving your batteries forward, maybe all the way forward, and dripping your trim tabs just a bit. That should keep it planted enough to run through that water at high speeds. It may also be necessary to mount an extra set of tabs closer to the keel.Rafael Lopez
My Facebook https://www.facebook.com/profile.php?id=100010183246751Comment
Yeah man! Broke that 70mph barrier!Comment
Thanks Rafael, by tabs near the keel, what do you mean?Keagan, in your case I think it's just battery placement. That river is not as rough as the waters I tested the Voracity in. Try moving your batteries forward, maybe all the way forward, and dripping your trim tabs just a bit. That should keep it planted enough to run through that water at high speeds. It may also be necessary to mount an extra set of tabs closer to the keel.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Thank you, I think this is what I need for my QMono !
Has anyone ran the x645 props on this twin ?
reason I ask is on my Limited Sport Hydro I tried a 447 prop and ran low 50's then went with a 645 that I now race with, picked up 4mph and dropped temps by 15-20*.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
