Honestly the epoxy you use isnt important as long as its quality stuff. I use west system but your local hobby shop should carry two part epoxy suitable for fiberglass, the longer cure is better. It's better if you cut some fiberglass strands into the epoxy once it's mixed. Have about 6-8" deep of cool water in your bath tub so you can stand the boat in it to keep the epoxy mix cool while it hardens. Anyway. Mix up each batch. Stand boat up. Pour each in seperate. If you don't wanna add too much weight to the front then do 20 grams each. Once poured, go set in your tub and let cure.
Thanks KFX. I'm going to look into doing this.Comment
Can you mix match battery packs? For instance I have 3 3s dynamite packs 50c 5000mah, can I use two of those with let's say 2 Turnigy nano or Turnigy hd for 6s per esc on the Zelos? I have an opportunity to get them without having to wait 2 weeks for them to arrive.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
I wouldn't. Too risky with the volatile nature of lipos.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Also, for some boats, like Sport Hydros, where getting enough forward weight is a problem, mixing in some lead shot and pouring that mixture into the tips minimized the amount of weight you have to add to get the boat's CG correct.Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
How do these packs fair off? The Turnigy's HD? I read some reviews of the nanotech and the zippy but notice a lot of guys use the Turnigy's HD's. I won't mix match since it's not a good idea but I would run the Turnigy's in my voracity instead.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
That's a really good idea. I've had mine "suck in" the deck surface a little once it cured due to the heat.
Yes, I've messed up a couple tips not having it in water. Never had an issue in water. Matter of fact I did this to my zelos the other day getting it ready for paint.
The lead shot is a great idea!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I decided to try a turdnigy hd a few months back. It was very strong (almost as strong as revolectrix) for the first few runs but dropped off in power dramatically. I think I lost about 8mph after several cycles. Never had this issue with any other battery. Confirmed it by using a different pack and my speed was back. Personally I wouldn't use turnigy batteries at this point. I always was against them but read how some people loved them so I decided to try for myself. Was hugely disappointed. These people running turnigys with fast boats, don't know what they are missing by not using a good battery. The only zippys I've seen used were in an aqua craft ul1 and they puffed very badly after a minute or so run time. He switched to another pack and didn't have that issue. That's all I know of them. I've never run them myself.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Thanks kfx, what packs would you recommend? Thanks for saving my hasty butt there. I don't have probs with the dynamite except one puffed but after the turmoil the voracity went through it may be linked to that.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
SPC or revoelectrix are nice batteries. My 70c SPC packs are awesome, never had a problem with them. I do run a pair of 2s 45c nano-tech's in my 24" hydro and they hold up good. They do get a little soft after a run but they never puff up, and I also race these packs in my 1/10 2wd buggies so they see lots of useComment
Smc (supposedly the same cells as Spc)
Spc (awesome batts and almost as powerful as the revos)
Hyperion (although I've never used these I've never heard bad about them)
Venom (I've used, last a long time)
revolectrix is my favorite and most powerful I've ever used
I've had good luck with smaller dynamite batts
Those bright green pulse are tough (I've used)
Gens ace but they are getting scarce (I've used)
Heard good things about giant power too
The new reaction packs seem to be doing very well too. Maybe someone else can confirm32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I made a list in another thread.....ill see if I can remember
The new reaction packs seem to be doing very well too. Maybe someone else can confirmProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Would any of the 3s pack from here be good? I can't access the SPC site for some reason, it wouldn't load. I would have to solder ec5 connectors on them. Male or female plugs? They both look alike, lol.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Revos come from Singapore. Every order I've made from them has arrived amazingly in 4-5 working days. I ordered on Sunday evening and get by Thursday.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
