  • Mxkid261
    • Jun 2015
    • 734
    #1741
    What are you going to run for props
    • Erroneous
      • Apr 2016
      • 451
      #1742
      Originally posted by stratus
      Are those 4050?
      C-mon bro....... Guess Ill wait for you to guinea pig this setup..... Sorry Stratus, reply was meant for Keagan.
      • Keagan-Z06
        • Mar 2016
        • 970
        #1743
        lol I was holding out, figure you would be the first. I might get a chance to run it Thursday.
        • stratus
          • Dec 2016
          • 110
          #1744
          nps m8.
          Yesturday had a run with my zelos,had some big waves so no full speed just had some fun bashing around
          Genesis 36", Zelos Twin 36"
          • fweasel
            master of some
            • Jul 2016
            • 4309
            #1745
            The waves make for some interesting acrobatics. I've never run on water like that. If the waves are that big on my pond, it's because there's a 50mph headwind!
            • Keagan-Z06
              • Mar 2016
              • 970
              #1746
              nps m8.
              Nice to see her go airborne on those waves, do you run heavy duty flexes?
              • banixj
                • May 2012
                • 107
                #1747
                wow! so crazy! never seen a speedcat trough sea waves!!!
                HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
                Futaba AIR TX/RX system with telemetry
                • stratus
                  • Dec 2016
                  • 110
                  #1748
                  Thnx guys it was really fun idd,in the full vid has lot more jumps and some crazy surf on the waves but had to cut em cause i was in the middle of it all the time :p !! As for the flexes i run with the stocks atm but im planing to swap em really soon,i was going to use wires but ill go with the ose upgraded ones instead since im thinking to upgrade motors also soon
                  • banixj
                    • May 2012
                    • 107
                    #1749
                    i also want to swap flexes but i'm not able to decide between hd flexes and wires... i don't understand if water come inside with wires...
                    • Team Lucas
                      • May 2016
                      • 300
                      #1750
                      water enters the wire drives if you don't use what Jeff suggest a (auto vacuum nipple) I believe what he said to use.
                      Zelos 36 stock 68 mph
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #1751
                        Hit 71.2 a while ago with new setup.
                        Seaking 180
                        TP4050
                        X447s
                        Revo 6s
                        I believe my Revos are on their way out. I wanna go back to using 4 packs vs 6s direct to each motor. She was running wet and could use some positive on the struts. Would it be recommended to prop up too? If I can get mid 70s to 80s I would be happy. Already am but that would be my goal. I predicted a modest 70mph with this setup. I know some of you guys reached these speeds on stock equipment but I'm still learning this hull.
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4309
                          #1752
                          Nice run Keagan. I just got comfortable running the boat on 2 3S packs last season and tried 4 on the last weekend out. It was a distaster in terms of how much the setup changed. I'll start over this spring sorting out the setup with four packs because 2min run times with two packs is just no fun!
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #1753
                            Thanks bud, I gotta weigh the Zelos, she sure feels heavy w those 6S packs. I also think the x447s won't net me 80mph. I'll try the props off my Zonda, 1815s with fresh packs and hold on for the ride.
                            • TRUCKPULL
                              • 2971
                              #1754
                              1815 's have more pitch the 447's
                              1.8" = 45.72mm x 1.5 = 68.58mm pitch
                              47mm X 1.4 = 65.8mm Pitch
                              Your 1815's are they the 17 degree rake props??
                              1815-17-45/2
                              Larry
                              • Team Lucas
                                • May 2016
                                • 300
                                #1755
                                Seaking 180
                                TP4050
                                X447s
                                Revo 6s
                                [ATTACH=CONFIG]149786[/ATTACH]
                                nice that's my goal with stock electronics.
