  • fweasel
    master of some
    • Jul 2016
    • 4286
    #1711
    Has anyone done anything to address the thickness, or lack there of, of the hull at the rear of the sponsons where the struts attach? I'm on a carbon reinforcement kick at the moment, and am debating a simple overlay approach on the inside or paying someone to cut some shims from carbon plate to sandwhich between the struts and the hull on the outside.
    Vac-U-Tug Jr (13mph)
    • REDLINE1
      • Jul 2016
      • 199
      #1712
      I don't think the shims would make it any stronger. I think an overlay would be better I would like to do that myself. Don't know if you could just flood the area with a layer of epoxy or lay some glass cloth in . Either of which I have never done so I would need some education on what epoxy/ cloth to use. I was surprised how thin that area was when I was remounting the struts with silicon sealer, but what do I know, just seemed thin
      • fweasel
        master of some
        • Jul 2016
        • 4286
        #1713
        Using appropriately sized carbon shims should spread the load out over a larger area of the rear face, potentially all the way to the edges, but would add thickness to the assembly changing hardware and driveline length issues. I suppose it won't hurt anything to lay carbon cloth over that area on the inside and I won't have to alter any of the hardware.
        REDLINE, I'll cut you two extra pieces of carbon when I trace a pattern tonight. Then all you'll need is a little resin.
        • REDLINE1
          • Jul 2016
          • 199
          #1714
          Sweet thanks! as long as the screws are long enough to accommodate the increased thickness should be no problem.
          • Erroneous
            • Apr 2016
            • 451
            #1715
            I actually cut some shim plates out of 25gauge galvanized steel and marine epoxied in to brace the hull. It had some pretty bad spiderweb cracks that where starting to flake off. The thick marine epoxy doesnt look the greatest on the inside where I couldnt sand it but is for sure 3times stronger than stock. Its in this thread with pics a ways back. It works, dont see why the carbon wont. The clear epoxy will for sure look better and lay out better.
            • Team Lucas
              • May 2016
              • 300
              #1716
              I have a question for you electric guys. What gets hotter 1st, motor or esc's? seems like my motors are hotter then esc's. thinking of cooling motors 1st then the esc's. running 6s each.
              Zelos 36 stock 68 mph
              • fweasel
                master of some
                • Jul 2016
                • 4286
                #1717
                I think it depends on the setup and how much throttle you use throughout the run. I cool my ESC's first, but after a prop change on my blackjack 29, my motor was hotter than the ESC. I swapped the cooling lines and everything was even again.
                • Mxkid261
                  • Jun 2015
                  • 734
                  #1718
                  Does it "seem" like they are hotter, or are you reading them with an actual thermal gun?
                  • Team Lucas
                    • May 2016
                    • 300
                    #1719
                    a gun and there 40 to 50 degrees hotter
                    • TRUCKPULL
                      • 2969
                      #1720
                      That is a big difference.
                      What are your actual temp readings:
                      ESC's - ?????
                      Motors - ????
                      Batteries - ????
                      Larry
                      • Rafael_Lopez
                        • Jan 2015
                        • 470
                        #1721
                        ESC's - ?????
                        Motors - ????
                        Batteries - ????
                        Larry
                        I agree with Larry, but what are the actual temps. If the motors are 120* and the ESCs are 80*, I would not worry about it too much. But is your motors are 180* and your ESCs are 230*, then I'd worry.
                        Also, are you running stock props?
                        Rafael Lopez
                        Product Developer-Pro Boat
                        • Team Lucas
                          • May 2016
                          • 300
                          #1722
                          I am running x447's and I will take bat ,motor ,and esc's temp tomorrow.
                          Thanks for replying guys.
                          • Team Lucas
                            • May 2016
                            • 300
                            #1723
                            BTW Rafael. another guy at the pond liked mine so much, he bought one, that's 3 and counting :) Running a couple of them in a heat is impressive to watch.
                            • fweasel
                              master of some
                              • Jul 2016
                              • 4286
                              #1724
                              Must be tough to keep track of your own boat!
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4286
                                #1725
                                What are your water temps like? I can't seem to find any of my temp data from the fall, but the local pond was probably mid 60's and I could run just short of 3min on 2 3S packs, stock electronics, x447 props, and the electronics we only warm to the touch. Even in the middle of summer, when everything ran hotter, I never saw the differences you're describing. I filed tear drops in front of each water inlet on the bottom of the hull, plumbed both ESC's in series before cooling a motor and then exiting the hull. I drilled out the water oulets with one size larger drill bit as well.
