  • gohan
    • Jun 2011
    • 494
    #961
    Originally posted by Chris VB
    No prob guys, it's got a ball point applicator and a brush plus it's got clear coat with a foam applicator (not needed on Zelos) but handy for other things. It's dupli-color not duplicate stupid spell check. Sorry for the sideways picture lol
    Here ya go...
    • Chris VB
      • Jul 2016
      • 21
      #962
      Lol thanks, that was probly really easy. I'm blaming the iPad
      • daHammer
        • Apr 2016
        • 23
        #963
        Where do you buy this Ford D6 - screaming yellow CAFM 0400 Chris?
        • Team Lucas
          • May 2016
          • 300
          #964
          I'll defiantly watch the temps, also negative is tilted down? To make the bow push down? Haven't ever adjusted them before.
          Did not see anyone answer you Chris on the strut/out drive adjustment. looking boat right side up, tilt drives down to lower bow, and lift stern, BUT.. your using thrust to lift stern so less forward thrust. The more level props the more they push forward, and not upward.
          Zelos 36 stock 68 mph
          • Chris VB
            • Jul 2016
            • 21
            #965
            Canadian tire is where I bought the paint.
            Thanks for the reply on the struts, helpful advice. :)
            • Team Lucas
              • May 2016
              • 300
              #966
              I am trying to keep drives level for speed but it wants to blow over, and adding weight to front, only slows it down. Been reading post's and I like the batteries post of them being on the side, they go in 1/2 inch more forward, and if running 4 batteries you can do side by side instead of down the middle. also gives you room to relocate ESC'S forward changing the CG 1/4 inch forward with out batteries weighed. Also relocating ESC's gives you a straighter cooling route. Just a idea I'm trying :)
              • Chris VB
                • Jul 2016
                • 21
                #967
                Receiver box upgrade
                If you wanna replace that sad stock zelos twin transmitter/receiver (no offence) you can use this traxxas rustler receiver box (part# TRA3628) to waterproof your electronics. Use the existing screw hole and a piece of servo tape on the opposite side and it's pretty sturdy. All the wires reach perfect including the receiver antenna (using futaba/4PLS) it works great!
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #968
                  Do you have it bolted down by one Allen screw? It's the same box in the Spartan. Love that little box. Antenna passes through the top without issue.
                  • Chris VB
                    • Jul 2016
                    • 21
                    #969
                    Ya, just one bolt and a piece of servo tape sandwiched between so it won't twist. It's rock solid, had flips without it moving. In all honestly the servo tape alone would hold it fine, that stuff is great.
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #970
                      Nice! Why did you upgrade servo if you don't mind me asking?
                      • IRON-PAWW
                        • Oct 2011
                        • 314
                        #971
                        Hey 36ers.
                        Noted Darin's air dams back a little. Has anyone tried that and noticed results? Just trying to calm the 48's bounce and tendency to lift at speed as well. Had thought about air dams or airflow spoilers top and bottom as well. Thought I'd just ask you guys. If you think plane wings..... then I agree with Darin about placing them on top.
                        PERTH AUSTRALIA
                        • paulfromtulsa
                          • Nov 2013
                          • 211
                          #972
                          I need to get her out to a bigger pond. I only got to hold wot for like 2 seconds but did manage to get 78.5. I feel she's got high 80s in her
                          Sent from my SAMSUNG-SM-G928A using Tapatalk
                          • Banzee
                            • Mar 2012
                            • 186
                            #973
                            How do you like the hobbystar lipo ?
                            • paulfromtulsa
                              • Nov 2013
                              • 211
                              #974
                              They have been good to me. Been using them for about a year in my boats and cars . No swelling and all cells stay balanced
                              • Erroneous
                                • Apr 2016
                                • 451
                                #975
                                Originally posted by IRON-PAWW
                                Hey 36ers.
                                Ive tried the spoiler on the top. Made a little difference but not enough to justify looking tacky. Imo. I will be trying out the dam underneath. Every time Ive gone titsup it seems like it was from pressure under the boat not lack of on top.
