Just got a ProBoat Shockwave 26
    I want to be clear on something here. I know most people has their idea on a certain prop size is supposed to go with a certain hull. That may be true to a certain extent and there Wil always be exceptions. This is one of those exceptions. I have tried numerous props on this shockwave. It just likes a big as prop. The motor that come in it is a 6 pole very torquey 1500kv motor. It's only turning about 17k rpm on a fully charged 3s pack. It will swing a big prop with no problem. Wait till the op posts back. His boat is going to pick up a bunch with a prop change. I tried an x642, it went slower. M645...slower. it just likes those big carbon props.
    • J.W. Pepper
      #47
      Originally posted by Fischetti11358
      The 45mm prop is out of stock on that site and on another site it says it's discontinued.
      Your right Steve is outta the Graupner carbon props, but he does have these... http://www.offshoreelectrics.com/pro...d=ose-2bld-316
      Bout the ESC... get yourself a Seaking 90A unit, cheaper, better & easier to program than the PB or Dynamite units.
      • J.W. Pepper
        #48
        The motor that come in it is a 6 pole very torquey 1500kv motor. It's only turning about 17k rpm on a fully charged 3s pack...
        Your absolutely right!! And the PB versions of those motors are closer to 1700Kv, I bought one from Darin Jordan while back, that's what he told me at the time. Picked up a 2nd for a spare. Can't help but wonder how the boat would do with the PB 1800kv motor from the IM31
        I've been checking out this prop chart... http://www.funrcboats.com/prop_chart1.htm#Chart - the x447 has almost the same amount of total pitch as the stock prop, 2.590 vs 2.60 - that explains why this boat can swing the larger props with no prob.
        Unfortunately, both Steve & these guys are out of the x445's... http://www.funrcboats.com/category.a...tpage=1&sort=4 - the say disco'ed on that page, but here... http://www.funrcboats.com/ProductInf...uctid=GR231745 - they say they're on order, ok, so which is it??
        Sux, after reading your posts, I very much wanna try the x445 size (on 3S), then maybe try the larger sizes.
        Can't thank enough for sharing the info, just wish it was before the props got disco'ed.
        • TheShaughnessy
          • 1431
          #49
          Here's my story on the x642. A customer came into the shop (I started working at a hobby shop a couple months ago) and wanted a metal prop for his shockwave, at the time I didn't even know there was a brushless version. A brushed one with steerable outdrive had just left the shop and I noticed it did indeed have a 1/8 th stub shaft and assumed his would have the same.
          Well I had him bring in his shockwave with his buddy who was picking up a m445 I did for a geico. I didn't really know where to go with a prop on the shockwave ( had lots of options after discovering he had a 3/16 shaft) I knew my sv27 ran well with the 642 so I said to myself, hey this is a similar power plant and hull so it should work well. I pulled out a 642 from my own collection and told him to give it a try and see how it worked. He called a couple days later and said he wanted two.
          I didn't really consider it was only running 3s. PB needs a 2200 ish kv motor. Like has been said 1500 kv is low rpm for 3s. A larger prop really does need to be used but I was concerned with torque roll and prop walk, not to mention heat. Last thing I need is a customer with a smelly boat. Folks around here haven't accepted a 2 min run time so I have to limit how much prop I can recommend.
          A 51 seems to be perfectly reasonable, I just figured something that large would create handling issues. I bet it would swing a x646/3 on 3s. I slapped one of those bad boys on my SV when I was starting out, finally smoked the esc when I ran 18 nihm cells in it.
          Ok rambling done
          • Fischetti11358
            • Apr 2014
            • 34
            #50
            So, I got my new 3s lipo the other day. It's a Nano-Tech 5000mah 65-130c pack. I'm not sure what the 65-130c means. Does that mean at low throttle it's 65 and at full throttle it's at 130?
            I also got my carbon props today. I ordered 42, 48 and 51mm ones. Which one should I try out first? How will each of them perform?
            I am going to run the boat tomorrow, so I was just curious about the props.
              Meh....turn it does some stupid rating thing. Still don't really know what it means or if it really means anything. I go by the lower number. It's basically a 65c (rated by them anyway, prolly more like 40-45c from what I've seen). Still easily good enough for what your doing. Always try the smaller prop first then work your way up. Let me know how it runs. Make a couple passes on stock prop...change...etc then you can see the difference.
              • Fischetti11358
                • Apr 2014
                • 34
                #52
                Will I notice a difference between the stock prop and the 42mm?
                  You should
                  • Fischetti11358
                    • Apr 2014
                    • 34
                    #54
                    Cool, can't wait to try it out tomorrow morning!
                    • Fischetti11358
                      • Apr 2014
                      • 34
                      #55
                      I just got home from running the boat. Right when I got there, I ran my old 3s lipo on the stock prop. I knew how it performed on this, but I just wanted to get a feel for the speed of it, so I can compare it to other props and battery.
                      After a short run, I put on the 42mm prop. I didn't notice any difference, so I brought the boat in and put on the 48mm prop. I noticed a difference with this one and it was plenty of speed to be fun. I ran down my old 3s lipo on the 48mm prop and then I put in my new, bigger 3s lipo. On the 48mm prop and new lipo, the boat was really fast and at times, bouncing and jumping a little. I ran the new lipo for a few minutes, then I put on the 51mm prop. The 51mm was very fast off the line, almost jumping out of the water for a second. On this setup, the boat was amazing!
                      Now, I have a few questions. Should the front of my boat be slightly out of the water, or should the boat be planted into the water? Also, my prop should be fully submerged right? How should I adjust my rudder and fins so the boat performs better? I haven't touched them since I got the boat. How will moving them up or down make the boat perform?
                        Told you! That puppy will move on out with the 51. Lol. Kinda goes against what most people think don't it?
                        I played with trim tabs and I dint have much luck. Mine ended up running the best the way it came. Knowing what I know now I could have bent the brass stuffing tube to play with it but I never did. You want it running as much out the water as you can without it chine walking or bouncing. When you play around with it you'll see what each thing does. Make only one change at a time tho! That way you can change it back if it gives you a eating effect.
                        • Fischetti11358
                          • Apr 2014
                          • 34
                          #57
                          Thanks, I'll play around with the positions of them next time out!
                          By the way, my friend has the same boat, so running them together is really fun! He put his 51mm prop on first yesterday. He drove for about 30sec and he must have hit something and flipped. His hatch and inner cover came off. The inner cover sank but we eventually got the hatch back. Time to grab a roll of hatch tape!
                          • Pa Yankee
                            • May 2014
                            • 1
                            #58
                            So the k series 51mm prop is the way to go? Debating between the 48 and 51.
                            • Sympster
                              • May 2014
                              • 7
                              #59
                              48 and 51mm Graupner K Series Props
                              48mm on 3S
                              48mm on 4S
                              51mm on 4S
                              I don't have a GPS on it, any idea of how fast it is based on the video?
                              51mm is good on 3S also. I did have an issue with prop walk on the 51mm on 4S. Sorry my buddies talk too much in the vide. I'll try to shoot some on open water.
                              This is on a HK 3-4S 100A Car ESC. Got a Seaking 120 coming. Looking forward to trying 5 or 6S with a smaller prop. May reduce the chances of prop walk. Will try to prop to stay the high 30s or low 40s. I don't think this hull can handle anything faster.
                              • bigcam406
                                • May 2009
                                • 236
                                #60
                                nice job on your boat and vids.the boat works really well.you're right about the hull,i wouldn't push it too much harder.
