Just got a ProBoat Shockwave 26
    I couldn't find it on 3s. Here it is on 4s
    Shockwave 26 brushless on 4s: http://youtu.be/mGtDESqpII0
      Originally posted by Fischetti11358
      Run them just like that? Don't have them sharpened or balanced?
      No need too. They are already sharp.
      • TheShaughnessy
        • 1431
        I did a x642 for a customer , he liked it so much he got two more.
          I can't remember if I tried that prop. I have one tho. We sat down and kept swapping props one day to find out it did best with the 51mm graupner. I know that's frigging huge for this boat but I think the reason why is the 6 pole 1500kv proboat Is low rpm with a lot of torque
          • Fischetti11358
            • Apr 2014
            • 34
            Looks like I'll be ordering some of those carbon props when I get home!
            I am also going to call the place I ordered the x435 prop from and see if I can cancel the order.
            • Fischetti11358
              • Apr 2014
              • 34
              The 45mm prop is out of stock on that site and on another site it says it's discontinued.
                I'll check when I get home from work. I think I have a few.
                • Fischetti11358
                  • Apr 2014
                  • 34
                  #23
                  That would be great, please let me know.
                  • Fischetti11358
                    • Apr 2014
                    • 34
                    #24
                    Also, will this fit?
                    http://www.offshoreelectrics.com/pro...od=oct-oc6pnmm
                      Yes but i wouldn't recommend it. They come off and you'll lose your prop and the boat won't move....so you'll go swimming if you don't have a way to retrieve it.
                      • Fischetti11358
                        • Apr 2014
                        • 34
                        #26
                        OK thanks. So just stick with the regular prop nut?
                        Also, I want to order those carbon props. What sizes do you recommend me getting since the 45 is out of stock.
                          Regular lock nut is fine. I'd get a 42, 48 and 51 and try those. On higher voltage it's gonna like the 42. On lower voltage, bigger.
                          • Fischetti11358
                            • Apr 2014
                            • 34
                            #28
                            Well I don't plan on running it on 2s, it's just too slow haha.
                            So on a 3s, it will like a small one like a 40?
                            Anything else you recommend me getting? Does anyone make a metal rudder?
                              I'm getting the feeling your not listening to me very much. 40mm is too small for that low of rpm. If you going to run 3s, get a 48. Quit worrying about running a small prop unless you change the motor and run a higher kv
                              • Fischetti11358
                                • Apr 2014
                                • 34
                                #30
                                Sorry I must have been confused.
                                So if I'm only going to be running a 3s, what other sizes should I get besides a 48? Maybe a 51?
