Just got a ProBoat Shockwave 26
Here's what happens when you try to go to fast with this hull
Shockwave 26 brushless modified: http://youtu.be/hpOcOZhVuV032" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Biggest I've tried is a 51. If you can, get an 80 amp proboat esc and run it on 4s with a 42-45mm prop. That's the fastest, most reliable setup. I'd keep everything else as is.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Ok, so I'll just order the 48 and 51 props.
I don't see the 80 amp ESC on that site. I see the 60 amp is $115. Do you recommend another company for an ESC, or stay with PB?Comment
Proboat. You'll have to buy one used in the for sale section here when one comes up. I'd get the 42mm while your at it. When you get the esc and a 4s pack you'll need the 42mm prop. It'll do around 40mph with that setup32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Do you have a link to the 80 amp ESC, maybe I can find it somewhere else.
What speeds will I be getting on a stock setup with a 3s and either the 48 or 51 prop?Comment
Jan has CNC'ed M642's FWIW - http://www.kintecracing.com/CNC_Machined_Props.html - have to scroll down aways. - I've been thinkin about getting one to try out on my IM31.Comment
Last night I was checking out the MG24 for a BL project using a PB1500Kv motor with 90A SK speedo. Part of my research involved trying to figure out what size prop to use with that setup, that's what made me think of it.Comment
Yes and yes.
Have you thought about adding some glass to the interior to stiffen up the hull?? That's my only real complaint about these boats, thin plastic on the sides and especially the top rails, see attached, I drew red lines on them.
I got one of those Bondo kits I posted pix of in this thread (post #9)... http://forums.offshoreelectrics.com/...tion-need-help to reinforce mine.
Now if I could just find time.Comment
FYI: BHCheiftan recommends that size for the IM31's
Jan has CNC'ed M642's FWIW - http://www.kintecracing.com/CNC_Machined_Props.html - have to scroll down aways. - I've been thinkin about getting one to try out on my IM31.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Dude - that's sick!
Now if I could just find time.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
