another mean machine set up
  • bustitup
    • Aug 2008
    • 3071
    #76
    Originally posted by Jesse J
    holy shoot batman! I just hope you had that thing securely flat on something while that stuff is curing! Nice work, boogieman.
    lol...yes I realized before I started that when I set the boat down and something that only supported the tunnel it put a bow in the hull deck
      • 9488
      #77
      Wow! is that CF or black glass?
        • 9488
        #78
        This video is the reason why I bought my MM !
        • Rumdog
          • 6453
          #79
          Holy friggen EFF!!! that is one damn fast mean machine!! that is my idea of sport boating!
          • bustitup
            • Aug 2008
            • 3071
            #80
            Originally posted by Mel279
            ok, try lowered it to 2.8v, because I've also get the same result till I lowered it to 2.8v. See if there is any different.
            Mel what are you using to program your 180?.....card or tx
            if your using card do you have a pic of it?
            here is what i'm using its ver2
            • Mel279
              • Dec 2008
              • 857
              #81
              http://cgi.ebay.com/ws/eBayISAPI.dll...lenotsupported
              I don't use any card,I just use the tx instead, its simple to program. So, have u set the cutoff voltage that I've suggested to u?
              • bustitup
                • Aug 2008
                • 3071
                #82
                no not yet...i'm just putting the boat back together from tearing it apart
                  • 9488
                  #83
                  it.... is.... Finished!
                    • 9488
                    #84
                    My first run with my MM, and wow! Cats are so cool!
                    not sure if it looks like it is running through the water right?
                    my cog is at 9"
                    • DISAR
                      • Aug 2007
                      • 1072
                      #85
                      Congratulations!
                      http://www.rcfastboats.com/
                        • 9488
                        #86
                        Thanks!
                        it seams very tight to the water, not sure if this is how is should run?
                        • bigpapa
                          • Apr 2009
                          • 2330
                          #87
                          looks good may loosen it up a little
                          • bigpapa
                            • Apr 2009
                            • 2330
                            #88
                            nice rooster tail !!!!!!!
                            • bustitup
                              • Aug 2008
                              • 3071
                              #89
                              Thanks!
                              9" is just about right for that boat...I use 9 1/2"
                              but are you balancing it properly?....I measure off the transome towards the front of the boat and put a mark at 9" (in your casr) in the side of the boat...I use the table edge and drab the transome towards me 9 1/2" ..the boat must balance or teeter totter at the measuring point...just shift the batteries forward or backwords to get it to balance on the mark you made......instead of a table edge you can use something perfectley round like a broom stick centered on the mark you made
                              hope this helps....if you have it balanced perfect it should ride just right
                                • 9488
                                #90
                                In the photo is was set at 9"
                                I'm new with cats, and I love this cat!
                                turns sharp and runs super smooth..
