Eagle Tree
  • R2315
    • Aug 2016
    • 199
    #61
    Alright thanks guys, I'm going to run it a few times and go from there! See what needs to be done if anything. I got a little over excited... haven't tinkered for a couple days
    • Tamelesstgr
      • Jun 2014
      • 1516
      #62
      Just so you are aware, if you are planning on doing the 300 amp modification the datalogger needs to be recalibrated.
      NEVER SATISFIED RACING
      Fine Design 32 V-Hull 4082+6s
      • CraigP
        • May 2017
        • 1464
        #63
        Update: I ran the ET data logger that I modified with the 10awg wire. It works just fine and the data logger showed a higher voltage level at max amps, so the wire is reducing voltage loss. I'm going to proceed to my second ET now.
        • R2315
          • Aug 2016
          • 199
          #64
          Thanks Craig! Good to know it worked out!
          • R2315
            • Aug 2016
            • 199
            #65
            Hi All,
            Has anyone experienced the Eagle Tree not recording all the temps properly? Every time I run it at least one temp is missing and its not always the same one.
            Thanks!
            • CraigP
              • May 2017
              • 1464
              #66
              I've had mine not data log at all, when I changed laptops. I had to set up everything from scratch. If it's showing in the live mode, then it should be there... I don't run two temps, so no experience with this specific issue. It's only the temps that are missing? Oh, one other thing, make sure your connectors are solid on the sensor. I think it will not lg if the data logger doesn't see a connection when it turns on. I had that happen on the tach sensor...
              • R2315
                • Aug 2016
                • 199
                #67
                Thanks Craig, ya it's weird because in live mode it all checks out.... I'll check the connectors next time.
                • Tamelesstgr
                  • Jun 2014
                  • 1516
                  #68
                  Originally posted by R2315
                  Hi All,
                  [ATTACH=CONFIG]154102[/ATTACH]
                  Thanks!
                  For my units I was not able to record (3) temps, I was only able to accurately record on Temp sensor A and Temp sensor C (1st temp slot and 3rd temp slot)
                  Are you using ET temp sensors?
                  • R2315
                    • Aug 2016
                    • 199
                    #69
                    Strainge..Yes, all Eagle Tree sensors. 1 motor loop and two standard.
                    Thanks
