Shocker First Maiden Run -- ESC Literally BLOWS through Hull
  • dmitry100
    • Mar 2015
    • 1264
    #196
    I just found an interesting telemetry system for just $50 bucks ... which is surprisingly cheap for what it is compared to some of the ones I've come across.
    >> http://www.hobbyking.com/hobbyking/s..._mAh_V3_1.html
    Might be worth a shot. What would you guys recommend? I believe the Spektrum radios have telemetry-- is it any good for the price?
    It sure would be nice to tie it in somehow to have some sort of last resort "kill switch" failsafe of some kind based on the temps or current, etc.
      • 7673
      #197
      Originally posted by iridebikes247
      Lower kv doesn't mean more torque, and running a bigger prop to make up for lost rpm will not work the way you imagine it will. If I remember correctly the shocker doesn't like huge props (think shawn told me this).
      Actually only said that the hull really liked to only go straight with anything bigger than 45mm props. Rudder input was a real battle of strength bettween the 'posi' effect of two props and the force of the rudder wanting to steer the boat. All boats really.
      No harm no foul Mike.
      • iridebikes247
        • Dec 2011
        • 1449
        #198
        My bad my memory was off lol.
        • dmitry100
          • Mar 2015
          • 1264
          #199
          So then there is a benefit to running smaller props on higher rpm setups then? Sounds like the boat being unsteerable is kind of a big negative lol
          • tlandauer
            • 5666
            #200
            Yes, on certain set ups. Some of KFXGUY's set ups are along those lines and he has a very clear goal and knowledge. ( correct me if I am wrong, Travis)
            However, first impression is hard to erase. Your first pair of motors were at certain kv and let's just say that had the set up worked , you would've felt that such a combo would be an everyday norm. Since you are now wanting to go for a certain margin of comfort----meaning you are dropping the kv, the immediate thought is to find an equivalent formula to gain back the speed. I am the same way, human nature.
            But there are many factors and it is going to be a process to find the ideal size prop for your hull.
            To answer either "yes" or "no" would be over simplifying the matter.
            Just my $.02, please feel free to correct me anybody!
            • kevinpratt823
              • Aug 2012
              • 1361
              #201
              There are pros and cons to both setups (some of which are debated regularly), and they vary with different hulls, but mainly larger props can begin to affect handling negatively, more so on some hulls/setups than others, but the can also be more efficient on some hulls/setups.
              Personally, for anybody new to boats I'm still inclined to suggest rpm's in the range below 38,000 for 4 pole motors just because there is a bit more margin of error on setup. Your 2050kv on 6s setup was over 45,000rpm, for something like that your driveline had better be running true and balanced, which yours certainly doesn't appear to be. With those set screw drive couplers and no stuffing tube supports alone I would be very concerned with high rpm's.
              I would imagine you could still get very impressive speeds out of a set of 442's in a slightly lower rpm range if you wanted to consider it.
              My private off road rc track
              https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
              • dmitry100
                • Mar 2015
                • 1264
                #202
                Ok :) Definitely will take these concerns into consideration. I'll be redoing the drive lines + adding inlays this week depending on when I'll get my new drives from Germany. Was thinking to add an MHZ bearing support for the flex/tube near the collets. What do you guys think of torque arms for the motor to add more support to decrease vibration-- have you guys ever use those before? I've almost never seen anyone use them in their builds for some reason...
                I've been researching diff telemetry kits for temp sensors but most of them seems as if they might be limited to like 1 sensor. Anyone have any experience with http://www.hobbyking.com/hobbyking/s..._mAh_V3_1.html or whether it supports more than 1 temp sensor?
                • kevinpratt823
                  • Aug 2012
                  • 1361
                  #203
                  Do some research on eagle tree telemetry. Steve sells some stuff here, and a lot of guys speak very highly of it.
                    • 7673
                    #204
                    And using it you can safely achieve your goals. It is well worth the time and money in keeping things monitored
                    • dmitry100
                      • Mar 2015
                      • 1264
                      #205
                      Does eagletree have any kind of real time transmitters like that Quanum system that shows temp data in front of you, or does it just do data logging?
                        • 7673
                        #206
                        Yes, it is called the Seagull
                        • dmitry100
                          • Mar 2015
                          • 1264
                          #207
                          Looks expensive as heck though. Almost the cost of an ipod... but without the bluetooth, wifi, or mp3 player. :D
                          • Local Boy
                            • Feb 2015
                            • 33
                            #208
                            Is this what you mean by "torque arms"?
                            I got this idea from nata2run ...Thanks Kent!
                            Aloha
                            • dmitry100
                              • Mar 2015
                              • 1264
                              #209
                              Yea, except that's the overkill version of the idea that I meant :) lol
                              • Local Boy
                                • Feb 2015
                                • 33
                                #210
                                LOL... I like overkill ... : )
                                Aloha
