Shocker First Maiden Run -- ESC Literally BLOWS through Hull
  • dmitry100
    • Mar 2015
    • 1264
    Hey guys,
    So I got a new Shocker hull w/ hardware -- 2x 180 Seakings V3's + 2x 1900kv 2200W 6pole motors, 38mm 3 blade props + 2x 6s revo lipos.
    I take it out for just a couple minutes with a few short bursts to make sure everything was looking OK. So after that I take it out of the water and as I'm walking back... I could start to hear a high pitched whistle going on within the hull and with the boat still in my hands a loud BOOM goes off... so as I almost *!***!***!***!** my pants-- I throw the hull onto the grass and run for my life. I could see 2 streams of smoke pouring out of the tips of the 2 front sponsons. After like 10-20 seconds I realize it'd be a good idea to disconnect the batteries to avoid any further damage or possible damage. I tear off the gorilla tape off the hatch as fast as I could... the only time I ever regretted having super strong tape lol and just start disconnecting all the battery wiring as fast as I could without trying to inhale of that smoke and I just let the hull sit there outside for at least 2 hours to let it vent out. I went back inside the house and took a shower. Even after the shower... I still smell like... the famous magic smoke that you guys keep talking about. My hands still smell. The entire hull smells. The lipos smell...
    So anyways as I inspected the damage I noticed that the only thing that was really hot was that 1 ESC that blew up... everything else (both motors and other ESC) was fairly warm but not even close to as hot. There was not a single drop of water inside the hull either. Water tubing had water in them too, so I'm kind of stumped here.
    Don't these Seaking ESC's have Thermal protection? What on earth would have caused it to blow up like that-- perhaps faulty ESC? :/
    Here are some pictures of the damage ... if you look closely it looks like the explosion blew through the front seams of the hull.
    One thing I'm surely thinking to do now is increase the size of the hull water pickup there and increase the cooling tubing diameter size from 3mm to 4-5mm.
    Thinking maybe even going as far as putting a small water pump in there to provide adequate cooling no matter what.
    And here I thought these ESC's would probably be overkill for these motors...
    Photo May 03, 2 48 50 PM.jpgPhoto May 03, 2 46 16 PM.jpgPhoto May 03, 2 45 59 PM.jpgPhoto May 03, 2 37 52 PM.jpg
  • tlandauer
    • 5666
    Sorry to hear that. It seems that these V3 have a tendency to do that------May not be a fair judgement but Randy had his pop too. Where as the V2 seemed to fair much better.
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      why seaking changed the bulletproof design they had is mind boggling.
      • dmitry100
        • Mar 2015
        • 1264
        Do you guys think this might of been caused by the motor-- possible short there, or just faulty piece of *!***!***!***!** ESC in this case?
          Make Total Destroy
          • Mar 2014
          • 1952
          Hard to say.
          One thing is for sure... All the water cooling in the world would not have stopped that from happening.
          • dmitry100
            • Mar 2015
            • 1264
            Any of you guys had any experiences with the Seaking warranty?
            • keithbradley
              • 3663
              Damaged motor? Problem in the driveline? It's possible that it was a faulty ESC, but I'm not buying into the notion that the V2 was so much tougher than the V3. I've beat the snot out of the V3 ESCs and they've taken it pretty well.
              www.keithbradleyboats.com
              • dmitry100
                • Mar 2015
                • 1264
                Keith-- Any way to check the motor aside from burning up another ESC? :)
                • dmitry100
                  • Mar 2015
                  • 1264
                  Also, Keith... You got any how-to threads about using that CF clothe you have on your site for inlays?
                  Not sure where to start with repairing those seams... would I need to crack open the entire hull to lay it all down?
                    One thing to check is make sure your motor mount screws aren't too long going into the motor and contacting the windings.
                    • IRON-PAWW
                      • Oct 2011
                      • 314
                      I had something similar happen. Was with a spanking new TP motor and 240 amp swordfish. Motor got red hot and esc charred to death after only about a minute. Pretty sure the issue was a faulty motor that went into meltdown and took the esc with it. Replaced that motor with a Nue and the esc with a Seaking V3. Boat now runs extremely well with no other significant changes. Dead TP was red hot when I got the boat back to shore, which gave the first clue. With new motor I was immediately struck with how much more free the drivine seemed to run on the bench. So I think in hindsight there was some manufacturing fault with that motor. I'd carefully inspect that motor for melted lacquer on the windings and other heat related internal damage. Might not be the motor but might be very XP if you don't at least check. Very well might just have been a faulty esc... either way you need new one those in any case. My v3 seemed to run a bit cooler with Properchoppers simple cooling upgrade.
                      PERTH AUSTRALIA
                      • tlandauer
                        • 5666
                        I thought Seaking has motor lock down detection?
                        If the motor is bad, just turn it by hand, it should feel mushy and the normal cogging is no longer articulated., as if there is wet sand in it. Look and see the color of the lacquer and compare to the other motor, also you can smell it if it is bad or going bad.
                        I have burned a Neu 1515 1y and a Leopard 4082/2200kv all on the same V2 ESC running on 4s2p, the ESC is still going strong today. My problem was I got a "voodoo" prop that was cupped and it just spiked the load on the motor that much more.
                        • iop65
                          • Mar 2013
                          • 367
                          wouldn't trust that cooling intake /flow for a second!
                          look at picture 2 and 3 : my guess is that the tube is glued in at 90° , that little spot in front off the intake is not going to do much concerning the waterflow
                          would buy some bigger brass/ alu tube and glue that in an angle about 45°, and sand some more area to make things more hydrodynamic : will scoop up a lot more water !
                          • dmitry100
                            • Mar 2015
                            • 1264
                            Does it help to use some water pumps for this sort of thing, or is a good proper cooling flow sufficient most of the time?
                            Also, how do you guys suggest I repair those cracked seams in the front of the hull-- that the pressure from the burning ESC created? Perhaps it might be a good idea to lay an extra layer of CF.
                            Looking at how even sunlight seems to peak through soo easily... kind of scary what could happen if it ever hits a wave going like only 70mph.
                            Do I need to put down an entire 1-2 layers of CF everywhere, or just in the more vulnerable areas like seams, mounts, etc?
                            Which one of you has a how-to follow along about putting down CF inlays/reinforcement :)
                            • T.S.Davis
                              • 6220
                              Nobody thinks 1900kv is too much for 6s? Alrrrighty thennnnn. Burn em if ya got em I guess. Seems we have this kv discussion every spring.
                              1900kv on 6s is going to produce plenty of amps. If you were running at partial throttle the amperage would have been even higher. Then run it for multiple minutes that way? Amperage kills ESC. Sometimes before the thermal cutoff even has a chance to do it's thing. A simple stuff tube bend too tight could have blown the speedo. A burr on the stub.
                              I beat the crap out of my Seakings. I haven't been able to burn one.
                              Noisy person
