custom Water blocks
  • NorCalZ71
    • Jul 2011
    • 293
    I appreciate your support and I hope I can deliver a product worth using on your builds.
    I am going to be starting a new job this month so that means 2 things.
    Good side is ill have funds to finish my mill asap and get working on this.
    Bad side is limited time to work on it at first.
    If this thread goes dead in the near future do not worry I am still going to produce a product from this. I will try to update as much as possible.
    Kevin.
    Nsr customs.
    • properchopper
      • 6968
      Kevin,
      Good luck with the new job ! Then hang tight - I have another "product idea" that should be fairly easy with a mill and is sorely needed
      • NorCalZ71
        • Jul 2011
        • 293
        Thanks. Pm me your idea and I can start drawing it up! I have a little evening time free for cad work.
        Kevin.
        Nsr customs.
        • properchopper
          • 6968
          Kevin,
          E-mail me at [email protected] - that way I can attach pictures
          Kevin.
          Nsr customs.
          • NorCalZ71
            • Jul 2011
            • 293
            ok guys i made some progress since i received the stock block from Alexgar.
            spent some time on auto cad finishing it up.
            gonna need to cut one out and figure out sealing but the piece on the left will be cut out of aluminum and will have optional water inlet/outlet ports (red lines)
            the piece on the right is the top. it will be cut from Plexiglas or acrylic and have optional inlet/outlet ports. (red circles)
            still gonna take a few weeks to get the mill running and get the prototype drawing converted to G-code and tested.
            but i am progressing slowly..
            keep an eye out for more design ideas.
            i have a few ideas brewing thanx to properchopper!! ill post here when i get any progress.
            • NorCalZ71
              • Jul 2011
              • 293
              Ok just a quick update. Got all my mill issues solved and parts to get it up and running are on the way!. As soon as I get it assembled ill get a prototype cut and checked and we will be in business.. lolz
              Kevin
              NSR Customs
              • kendt
                • Jul 2011
                • 557
                That's looking great. I wonder if they should just be sold as a kit. The buyer could use silicone to seal it before installing it. Wouldn't be a huge deal. Just a thought.
                • NorCalZ71
                  • Jul 2011
                  • 293
                  #23
                  That's a thought I had too. Or I may silicone them before shipping. Not sure yet.
                  Kevin
                  NSR Customs
                  • Ken Haines
                    Racer
                    • Jul 2007
                    • 647
                    #24
                    Spec Motor Lead Cooling Blocks
                    Hey NorCalZ71,
                    I was at the Michigan Cup a few weeks ago and noticed a cool invention
                    by Terry Davis. He had a water cooled block on his spec motor leads.
                    The motor lead issue is a sore point with many racers. The stock insulation
                    at the point the leads enter the can heat up and quickly short the motor
                    causing a premature burn up of the stator windings. Ny placing a water
                    cooled block over the leads near the entry point it cooled these wires
                    and also served as a manifold guide to the ESC. I do not have any pics
                    but this simple cooling block with 3 holes for the wires and an inlet and
                    outlet port for the water connections could be made in a variety of ways.
                    I would suggest that extra insulation be provided at those 3 holes so
                    this heat sink does not end up being the shorting point as well.
                    Just thought this was an ingenious idea.
                    Your Thoughts ?
                    Ken
                    TenShock Brushless / Pro Marine
                    INSANE Boats / Rico Racing/ Castle Creations
                    2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
                    • NorCalZ71
                      • Jul 2011
                      • 293
                      #25
                      That kind of thing is exactly why I opened this thread. I don't have an aq motor to design from, I do need one tho..
                      I think that I could do something along what your describing. I'll look into it as soon as I have a prototype of the t180 plate.
                      Kevin.
                      Nsr customs.
                      • kendt
                        • Jul 2011
                        • 557
                        #26
                        Kevin
                        NSR Customs
                        If you sell em as kits it is less work for you and less headache. At least nobody can ever say their esc blew because you didn't seal it properly.
                        • Alexgar
                          • Aug 2009
                          • 3534
                          #27
                          Got any pre.production pics for us to drool over Kevin ?
                          • NorCalZ71
                            • Jul 2011
                            • 293
                            #28
                            I'll see what I can do tonight.
                            Kevin
                            NSR Customs
                            • NorCalZ71
                              • Jul 2011
                              • 293
                              #29
                              Sorry guys I was gonna try to render it in 3d on mastercam for ya but my old laptop refuses to load AutoCAD and I didn't save it in a dxf format.. ill convert it on my other laptop 2moro and see if I can't get the g-code and renders done.
                              Kevin
                              NSR Customs
                              • Jim Osborne
                                • Feb 2012
                                • 28
                                #30
                                This is an example of one I made to fix the width issues.
                                Jim
