Esc?
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    #31
    You just need to grab a water jacket for it from ose cause I don't think Keith has them, not sure tho
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      #32
      Looks like Keith has the water jacket for it right underneath the motor hehe
      • awfireman
        • Jan 2013
        • 90
        #33
        yes, just finished the purchase. Got motor and water jacket. The SK 180 going to order from OSE. Thanks for your help and will let you know how this set-up goes.
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          #34
          Nice man. That's a garunteed awesome setup. 15 degrees motor timing which the 180 esc is ore programmed to anyways. I suggest grabbing the program card for 10 bux, well worth it
          • Megabiker98
            • Jan 2013
            • 253
            #35
            Yes that motor will work with the stock motor mount
            • awfireman
              • Jan 2013
              • 90
              #36
              just ordered the SK 180 from OSE. Should have everything by weeks end. Thanks again guys
              • awfireman
                • Jan 2013
                • 90
                #37
                dont know anything about the timing, one thing at a time!
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
                  #38
                  Ok ok let us know when you're ready to program it and we will help ya out.
                  • BHChieftain
                    Fast Electric Addict
                    • 1964
                    #39
                    I'm just vouching for the neu 1515... simply an amazing motor. I run one in my syncron.
                    Chief
                    • lenny
                      • Sep 2010
                      • 4296
                      #40
                      A 36mm motor would work just as good in this hull,
                      With out all the torque to.
                      The boat hull is very light to begin with.
                      ? ONLY IF THEY WORK
                      • awfireman
                        • Jan 2013
                        • 90
                        #41
                        HV....just got the SK 180 in the mail today. After reading looking at the ESC and reading instructions I have a few questions. Please dont laugh but Im new to all this but want to learn.
                        1) The SK has no on/off switch like the stock dynamite. Does this need one? and if so how do I do this
                        2) I noticed it has 4 ports for the cooling hose. Does it matter how I run the hose? I imagine one in, then a very short section of hose to connect the two, then one through the motor and out the side
                        3) Does it matter the way I orientate the ESC inside the hull to get better cooling?
                        4) IS this easy to program with my stock receiver/transmitter that comes with the BJ 29? It seemed rather confusing.
                        5) what is that "thing" that is connected to the ESC.? it has a black and red wire and black shrink wrap over it.
                        6) What up with the "green ring" that is on the wire that connects to the receiver?
                        Thanks for you help. I know these probably sound like stupid questions but this is my first time connecting a new ESC and new motor. Ive only had the boat for 3 months. But Im hooked! Its a ton of fun and eager to learn about this hobbie
                        • Megabiker98
                          • Jan 2013
                          • 253
                          #42
                          No it doesn't need an on off switch, it turns on once it has power, yes on the cooling on in and short u on the other side them out to other, no the orientatation doesn't matter, programming without the card is probably fairly hard, the "thing" connected to the esc with the black and red wires are extra capacitators, as the green thing is just to reduce the amount of length on the wire.
                          Edit: man that shipped SUPER fast!!!
                          • awfireman
                            • Jan 2013
                            • 90
                            #43
                            Edit: man that shipped SUPER fast!!![/QUOTE]
                            Yeah it did, have ordered other items from OSE and Kintech and had no problems. OSE is right in Chelsea,Ma only about 50 miles north of Plymouth, so that helps! Waiting on the motor and 5.5 bullets from keith bradley so I can solder,mount,connect and hopefully run in the next week. Im sure I will have some more Qs before its done! lol
                            Thanks for all your help guys
                            -Fireman
                            • Megabiker98
                              • Jan 2013
                              • 253
                              #44
                              Where do u have ur strut set?? If u go check my last thread in the mystic category, Lenny and a couple other users have me some setup tips, that would be useful as u have basically the same setup as I do, only thing different is prop different brand battery and motor, but the hull is almost exactly the same
                              • Heaving Earth
                                Banned
                                • Jun 2012
                                • 1877
                                #45
                                The green ring is there to absorb signal to reduce interference between components.
