Genesis Cat with 4074 leopard motor
Thanks Vid! I am working on my Genesis now. Gathering parts still. So far 2000kv leopard, 180 seaking, traxxas 2075 servo, upgraded steering rod, and bought 2 5000mah 40C 4s lipos. Have a X640 prop to start with too. Ponds are frozen now so I have to wait.. no fun.Go Fast...Turn Right...Comment
hi all great forum im new to rc and have purchased the genesis cat and am going to setup as video200 has leopard motor 4074 2000kv 4s2p 5000mah 30c 180 turnigy esc and a x642 prop
want a nice reliable boat to start out and am wondering what else i need to buy to finish this build (driveline,cooling,servo and connector size and wiring size any info would be helpful thanksgenesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progressComment
you need a 4-40 steering rodd. i changed my driveline to .150 flex and just drilled out the original strutt to fit a 3/16 shaft. you wil need a cooling jacket for the motor. my connectors are original on the batteries and the rest is castle`s 5.5mm i beleve.
i found that a prather 220 works better then the X642 for me. but im waiting for a M642 from eggneg that i wil test when the water gets liquid again.
the servo in mine is a EXI D226F.
it probaly goes without saying. but the prop needs to be PROPPARLY balanced and sharpend. so when you order your prop. go for the B\S ones. it wil give you ALOT better speed and way less frustration then if you try to run with a "raw" prop.Comment
thanks mr 200 the prop i bought is from here and it is b/s. (balanced and sharpened lol)
The servo i bought is a turnigy digital servo 620dmg+hs high torque 10.6kg/.13s/52g is this adequate or should i buy a analogue one
My batts have 4mm bullett connectors the esc is a turnigy marine 180a dont know what connectors it has yet should i just buy 10 pairs of 6mm connectors and make all connections same.
I Ialso need to make a harness to run parrallel batts would this all be better in 6mmgenesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progressComment
never tryed that servo but im shure you wil be just fine as long as you get the steering rodd swapped for one that dont bend the seccond it notise that you actually gona make the rudder turn.
bigger is normaly better. i havent botherd all that much with changing things sinse nothing in my setup is getting warm.Comment
Anyone ever use the Traxxas 2075 servo? Any input would be greatly appreciated. Thanks.Go Fast...Turn Right...Comment
do you need a different mount to fit the leopard 4074 with the ose xl water jacket 40x57mm or just standard genesis mount with a wedge under the back and a cable tiegenesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progressComment
thanks video i think ive got all i need now to set it up just gotta wait for parts and boat to show up
(think diesel has the cable tie setup or had it in his cat)genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progressComment
