Genesis Cat with 4074 leopard motor
  • video200
    • 837
    #46
    i think most of the reason why people dont use 5s is that it would give you 42 000 rpm with a fresh battery on a 2000kv motor
    • iamandrew
      • 577
      #47
      Hmmmmmmmmmmmmmmm
      so I should just stick with the 4S 2P and the 2200kv instead?
      My watercooling setup seemed to work pretty well last time I took the boat out, Ill rebuild the boat and take some pics
      • video200
        • 837
        #48
        i wouldent go more then 4s on 2000\2200 but thats just me.
        im happy with the speed i get from the 2000kv. orderd some new M series prop for it so with a little luck i should be able to breake 60 mph (so far max speed been 56,8)
        • iamandrew
          • 577
          #49
          yeah its just id prefer to keep the 4S batteries that ive allready got, they also seem to be very useful for other RC things
          I got almost 10 minutes of run time out of the batteries with the stock motor, but it needs to go!
          • video200
            • 837
            #50
            well if you look at the vid i posted of mine. that vid is 8 minutes and changes.
            uses more when i can do WOT all the time but still last a good 5-7 minutes
            • Diesel6401
              Memento Vivere
              • 4204
              #51
              Originally posted by iamandrew
              Is 5S not used by many people? or is the reason people dont use 5S is because theyr run 2 3S packs in series?
              I run 5s all the time and so do a bunch of other people. 2000kv is bit much on 5s that's all. You gotta run the voltage that's appropriate for your any given setup.
              Hmmmmmmmmmmmmmmm
              Reason I say no to 5s is not because of heat issue, but rpm issue. To high rpm lots of wear on motor/drive compoents and to much rpm can make the prop inefficient and carries to high of a load on a single drive. Higher rpm is ok on a twin setup because the work load is shared. On a single motor 26-32k for target range, depending on what type of setup im looking for.. That's just me...
              - Diesel's Youtube
              - Diesel's Fleet
              • Basstronics
                • Jun 2008
                • 2345
                #52
                I will be placing my Genesis on order after Christmas- waiting on my HK gift card.
                HK did it again. Im looking at the $303 price tag like man I cant afford it. Click on buy and it goes into my cart at $192... Hell Ive seen people asking almost that for the hulls!
                • Basstronics
                  • Jun 2008
                  • 2345
                  #53
                  Would the Castle 1717 1580 kV be overkill or would it work well?
                  How about the 1512 1800 kV.
                  I dont have an ESC or batts yet, so Im open to ideal setup.
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    #54
                    1717 would work (big that's for sure), would be a rocket.. The 1512 is too small. I'm still a fan of the leopard 4082s in the genesis. JMO
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Basstronics
                      • Jun 2008
                      • 2345
                      #55
                      Sounds good boss.
                      I think im down for it.
                      • b.mcdaniel.2009
                        • Sep 2010
                        • 1641
                        #56
                        Originally posted by Diesel6401
                        The motor pictured is a 4074 2200kv, I was just showing you how I did it. As far as the 4082 I suggested that motor for another member here for his genesis and he posted great results. Looks like a CF48 maybe, here's his vid http://www.youtube.com/watch?v=KJckfHpAHZo
                        This thread may help: http://forums.offshoreelectrics.com/...ad.php?t=18755
                        Man that boat looks good LOL
                        Going to try 2 4082 in a CF Genesis hull from FighterCat!!!!
                        ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
                        • b.mcdaniel.2009
                          • Sep 2010
                          • 1641
                          #57
                          I changed out my 4082 for a 1717 air version with the T-180 on 6s, with a x645 prop and it toke flight around 68mph.
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            #58
                            That's outta control man lol... Get some video of the please
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • b.mcdaniel.2009
                              • Sep 2010
                              • 1641
                              #59
                              Soon as the dang lake unthaws....... Winter SUCKS!! My neighboor's and i throw bubblers in the water around our docks so the water doesn't freez and srew them up. It leaves about a strech of unfrozen water abot 10' wide and around 200' feet long before you get to the bend, but i dont have the ballz to try it out with a boat in the 65+mph range, may not get stopped and whoops there goes the drive.LOL
                              • Basstronics
                                • Jun 2008
                                • 2345
                                #60
                                Nice...
                                My 1717 car motor is on the way.
                                Going to order the Genesis after Christmas.
                                I also have a 4074 2000 kV Leopard sitting here. I think my 25" Prince mono wants to play with it!
