please help me with my boat i want MORE speed
  • Woodz
    • 40
    thnx so much both of you lots of help ive spent lots of money on this boat and its awsome just like everyone want loads of speed!!!
    • Woodz
      • 40
      oh and diesel would i have to use two of those packs?
      • Diesel6401
        Memento Vivere
        • 4204
        Keep working at it buddy, you'll get it the way you want it.
        - Diesel's Youtube
        - Diesel's Fleet
        • Diesel6401
          Memento Vivere
          • 4204
          Yes, both packs would need to be run together in series. Are you OK with wiring series and parallel?
          Let me look for a 4s pack as well that you can run by itself or 2 in parallel.
          - Diesel's Youtube
          - Diesel's Fleet
          • Woodz
            • 40
            ok thnx i know im a noob
            • Diesel6401
              Memento Vivere
              • 4204
              2 of these in parallel http://www.hobbycity.com/hobbyking/s...idProduct=9958
              For the money and what you want to do with your boat, run the 2 2s packs in series
              - Diesel's Youtube
              - Diesel's Fleet
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                You are learning laddie and enjoy the hobby. Research...Research
                Douggie
                • Woodz
                  • 40
                  so if your running say 2 2cell 7.4 volt each at 2200mah and the same at 4000mah in series which would be better????
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    i also found this 1 i dont want to sound like im contridicting you http://www.hobbycity.com/hobbyking/s...E_Warehouse%29
                    Your fine. I had a pair of those hobbycity hardcases and they are kinda bulky and take up some room.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      If you order from Hobbycity make sure you activate the warrenty code on the back of the batteries their have been some cases of people receving dead cells from stock. I don't want to scare you just inform you. I have not experienced that myself (knock on wood) but have had a some cells die after continued use.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Woodz
                        • 40
                        yay got my lipo today i got a turnigy 3000mah 4s battery just need to get some bullet connectors now then of to the lakes yayayayayayay!!!!!!!!!!
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          #27
                          What "c" rating is that battery? At only 3000mah it may not be up to the task, that motor can pull some amps. The mah rating effects more than just run time.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Woodz
                            • 40
                            #28
                            it has a 25c constant and 30c burst for 10 seconds???
                            • Woodz
                              • 40
                              #29
                              has just got back from lake and my boat went 35 mph yay thts 12 mph better is that more like it?
                              • Diesel6401
                                Memento Vivere
                                • 4204
                                #30
                                That's a ton better than what it was before . How were your temps? If temps where ok you can start playing around with different props, take it slow and always watch/monitor your temps and don't jump to high in diameter.
                                - Diesel's Youtube
                                - Diesel's Fleet
