thnx so much both of you lots of help ive spent lots of money on this boat and its awsome just like everyone want loads of speed!!!
please help me with my boat i want MORE speed
2 of these in parallel http://www.hobbycity.com/hobbyking/s...idProduct=9958
For the money and what you want to do with your boat, run the 2 2s packs in seriesComment
i also found this 1 i dont want to sound like im contridicting you http://www.hobbycity.com/hobbyking/s...E_Warehouse%29Comment
If you order from Hobbycity make sure you activate the warrenty code on the back of the batteries their have been some cases of people receving dead cells from stock. I don't want to scare you just inform you. I have not experienced that myself (knock on wood) but have had a some cells die after continued use.Comment
What "c" rating is that battery? At only 3000mah it may not be up to the task, that motor can pull some amps. The mah rating effects more than just run time.Comment
. How were your temps? If temps where ok you can start playing around with different props, take it slow and always watch/monitor your temps and don't jump to high in diameter.
