please help me with my boat i want MORE speed
  • Woodz
    • 40
    hello i have a 25" hor rocket in america know as a prince and im running a stinger drive with a 35mm 2blade prop with a 2300kv motor,60amp esc,and on 1 3cell 4000mah 11.1lipo it weant 19 and 2 lipos in parralel went 21 mph please help me i need more speed??
  • Diesel6401
    Memento Vivere
    • 4204
    Welcome to OSE, and I'm sure we can help you figure this out.
    What size motor is it, 380 size (28mm) or 540 size (36mm)? Is the boat getting on plane? Did you try 4s? or 2 2s in series?
    - Diesel's Youtube
    - Diesel's Fleet
    • Woodz
      • 40
      reply
      its a 540 and yes it gets on the plane quite well?
      • Diesel6401
        Memento Vivere
        • 4204
        I would run 4s in that set-up. I run a h&m no step (vid in my signature) it is just a few inches smaller then yours at 23" and it runs fast on ul-1 power with 4s. I think you need more juice.
        - Diesel's Youtube
        - Diesel's Fleet
        • Woodz
          • 40
          i have ran it in 6s in parallel is tht the same other than having 2 more cells?
          • Diesel6401
            Memento Vivere
            • 4204
            No way to much RPM on 6s. Try 1 4s pack 5000mah 30 or 40c should run nice. Or 2 4s packs in parallel or 2 2s pack in series. Stay away from the 6s packs. 6s may damage the motor if it hasnt already, that' over 50,000 unload rpms.
            - Diesel's Youtube
            - Diesel's Fleet
              Okay, you have to understand what we mean by parallel and series.
              Series is wiring two packs together connecting the positive wire of one pack with the negative wire of the other.
              Parallel is wiring two packs together connecting the positive wires of each pack together and the negative wires of each pack together.
              Each cell is 3.7 volts.
              Two cells in series is 2S and has 7.4 volts.
              Two 2S packs in parallel is 2S2P and has 7.4 volts.
              Four cells in series is 4S with 14.8 volts.
              Etc.
              Putting packs in parallel does not increase speed, putting them in series does. Three 2S packs in parallel (2S3P) will have the same speed as one 2S pack. If you put two 2S packs in series you will have 14.8 volts and a lot more speed than your 2S setup.
              • Woodz
                • 40
                oh tht was the answer to my next question so i should go for a 4s pack is this 1 ok to use
                • Diesel6401
                  Memento Vivere
                  • 4204
                  http://cgi.ebay.co.uk/14-8v-5000mAh-...item19bda5e6f2
                  I think the overall problem you are having and I may be wrong is power issues. Not enough Juice. Their are guys here that run those akku packs here is a thread.. I use turnigy and zippy packs from www.hobbycity.com they are not the best but work for what I need them for. If you really want to see what your boat can do get some hyperion g3's or some thunderpower packs.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Flying Scotsman
                    Fast Electric Adict!
                    • Jun 2007
                    • 5190
                    Where in the UK do you live, I trust it is not in Scotland, as my intelligence will come into question.
                    Yes, that battery will work, but that is a cheap price.
                    Douggie
                    • Woodz
                      • 40
                      i live in south england and its cheap is the main problem as im only 16 and have no job atm?
                      • Diesel6401
                        Memento Vivere
                        • 4204
                        These would work: http://www.hobbycity.com/hobbyking/s...idProduct=9956
                        Same packs German warehouse. http://www.hobbycity.com/hobbyking/s...dProduct=14370
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Flying Scotsman
                          • Jun 2007
                          • 5190
                          Do not worry mate, being born their explains a lot. Yes, buy that battery and I remember having not too much cash.
                          Douggie
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            Gotta start somewhere. I hope you are having fun with the hobby! Do some reading on this site to help set-up your boat up to run great. They also are called Delta force 26 clones or copy, so do a search on df 26's are the information provided can be applied to your hull. Happy boating!
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Basstronics
                              • Jun 2008
                              • 2345
                              Gotta do something with the prop. Those speeds in MPH and what are you using to tell the speed?
                              To be honest thats pretty darn slow! My 12" boat does over 21 MPH.
                              Look for the Prince vids. Most of the setup info is listed on each video. I havent had the Eagle Tree GPS in it yet, but I would venture to guess mid 30's. I got a new motor for it and Im currently reworking the setup with new motor mount and such.
