Genesis cat,,,
  • Dangerous_Toys
    Hiding from the Ole Lady!
    • Apr 2010
    • 2250
    #136
    Wow! Square 4mm flex cable. What kinda s**t is that? I got rid of that and used a .150 to 3/16 prop shaft. Got rid of the stock strut and put on a 3/16 speedmaster strut I had lying around. Its a flat bottom strut for Hydro's and Rigger's but who cares, i'm not racing it, its only gonna be for sport. I had to take a little off of the rudder bracket to get the mounting holes to line up, but it worked out good. Just need a little shrink wrap on the stuffing tube to strut and she'll be set. Then I need to change out the stock esc. I have a hydra 120 I can use. Will that be good enough to run this on 4s with the stock motor? Maybe I'll change that out to a 9XL...
    ? WHAT RULES?
    • Diesel6401
      Memento Vivere
      • 4204
      #137
      Very nice Dangerous.
      I got some work done today. I got the 180 mounted and removed the battery trays and laid some velcro down on it. I also laid a bead of CA around the servo mount and rx mount to make it stronger. Now just waiting for a order from Steve (OSE) and Jan (Kintec) to come in and she will be ready to hit the water.
      - Diesel's Youtube
      - Diesel's Fleet
      • Dangerous_Toys
        • Apr 2010
        • 2250
        #138
        Lookin good Diesel! How did you remove the batt trays? Heat gun? I laid epoxy on the servo and RX mounts. I also removed the epoxy on the stuffing tube and glassed it in with finishing resin. I'm gonna put in a CC Hydra 120 and run the stock motor on 4s. I will eventually put in a 9XL and run it with a little more voltage.
        ? WHAT RULES?
        • Diesel6401
          Memento Vivere
          • 4204
          #139
          Even better I used my finger lol, i started pulling up on it to see how strong it was and to decide what I would need to get it off and as soon as i pulled it came half way off, so I just grabed a flat head and pried it off the rest of the way. Other one was the same, no damage done and that's when I figured I should make the servo and rx mount stronger.
          - Diesel's Youtube
          - Diesel's Fleet
          • befu
            • Aug 2009
            • 980
            #140
            Originally posted by HYDROJERRY
            just ordered it they showede to have 1 in stock and cheaper than HK ,,,,
            So, what did it end up costing you delivered?
            They have them in stock now, but price is 234 pounds with 17.5% VAT. So you take off the 17.5% and you get a sale price of $199.14 pounds x 1.52 = $303 USD + shipping. Are prices cheaper if you log on?
            If I remember, it was not the same boat but had different ESC and/or motor?
            Thank you sir,
            Brian
            • HYDROJERRY
              • Jan 2010
              • 2503
              #141
              Mine was 251pounds or euros or something but ended up being like 270 something i beleive..and came with the stock 2075 6xl and the seaking 120a esc but stock 4mm flex (yuk)..
              • befu
                • Aug 2009
                • 980
                #142
                Thank you for replying with the info.
                $270 ish USD ain't bad! When I am ready to order, I will have to send them an email. Unless Steve is planning on ordering in a few for non advertised specials.
                Brian
                • HYDROJERRY
                  • Jan 2010
                  • 2503
                  #143
                  I had to become a member of the site to purchase it there, maybe thats the difference...
                  • Alfa Spirit
                    • 2131
                    #144
                    @ Dangerous_Toys : What' s that prop and that bullet nut? Sorry but they look strange
                    • Dangerous_Toys
                      • Apr 2010
                      • 2250
                      #145
                      The prop is an Octura 1440 cupped and a OSE self locking prop nut 10-32
                      ? WHAT RULES?
                      • Alfa Spirit
                        • 2131
                        #146
                        If you want to run the Genesis with 6S, a 1500/1600kV motor will be perfect, and don' t forget the ESC
                        6S (2x3S) and NEU motor 1521/1Y 1577Kv
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          #147
                          Well ran mine this weekend,,, ran pritty good hard to line up straight and after about 4 or 5 laps it died in the middle of the lake so had to go get it ofcorse buy the time i got to it, it was close to the shore on the other side(dam) but got it in the motor was 132,,everything else was ok,,it died cuz one of my conectors i solder came apart but why was the motor so hot...
                          • Flying Scotsman
                            Fast Electric Adict!
                            • Jun 2007
                            • 5190
                            #148
                            Reason....Large hull.....small cheap high Kv motor ...end of story.
                            Douggie
                            • iamandrew
                              • 577
                              #149
                              Hi everyone! long time reader ! first time poster!
                              Ive finally received my genesis cat in the mail! turned up undamaged and was honestly a lot better quality than what I was expecting.
                              Will probably spend some of the weekend putting it together
                              Ive got the HK-GT2 radio, 2x 4S 4000 Lipos
                              speed controller dosent seem to have anything written on it.
                              Anyone got any tips for setting it up? I plan to keep it fairly stock
                              I want to run the 4s bats in parallel
                              would it be a good idea to get the 180 turnigy ESC and run BEC as well? rather than having a seperate battery pack?
                              things have sure changed since my old boat! which was basically all old tamiya RC car stuff in a boat! not even watercooled hehehe
                              Thanks!!
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                #150
                                Douggie
                                The motor is 2 pole and the info said to set the timing at 0 and work up but if the motors hot then its not going to get cooler with more timing woud it..
