New Hobby King Cat (Surge Crusher)
  • electric
    • May 2008
    • 1744
    #76
    Originally posted by Basstronics
    Im having the same water issue with my "small bolt".
    I am going to try the heat shrink. Did you use a ton of grease on that cable?
    I suppose more than usual, but nothing to crazy. I have run several FE boats and have not encounted this problem at this degree ever. See how it "pushed" all the grease up through the shaft into the boat. That is strange. I have never seen a shaft drive do that. That is why I am thinking somehow we are getting water pressure pushing up the shaft. Which leaves me wondering about the strut design.
    This the "smallest" FE boat I have run before, maybe this is more common with smaller boats?
    • electric
      • May 2008
      • 1744
      #77
      Originally posted by vasy
      Like miss Elam I guess, can't find a good way to seal inside.
      I just use this stuff, take the receiver out of the package, cover it with one layer, let it dry for 10 minutes, cover it again with the 2nd layer and let it dry overnight. Put it back into the case and just run the receiver open, underwater or whatever. I only leave pins and top of the led not covered (I just paint over the LED and then use my finger to clean the top of glass right away)
      Now your receiver is 100% waterproof... I once flipped my boat and it sunk 3/4 way down with just the nose pocking out. I had full control for 20 minutes, the time it took to drive the boat back (long story) and the receiver still work 100% many weeks after and I even never bothered to dry it.
      Cheap insurance, I do it in all my boats now and have never had an issue and almost all receivers got covered in water one time or the other.
      Thanks. Just placed my order...
      • crabstick
        • Jul 2008
        • 954
        #78
        if any water can get into the driveline before the drive dog, it tends to hit the drivedog, and turn around and come right up the stuffing tube and into the boat.
        I run the stuffing tube right through the strut and put a bit of heatshrink over where the tube enters the strut.
        My boats run dry!
        Matt.
        FE, Nitro and Gas racing in Auckland
        www.rcboats.co.nz
        • Basstronics
          • Jun 2008
          • 2345
          #79
          This may be a dumb thing... but...
          I havent checked this either.
          I realize they make left and right lay flex cables. It may be possible the lay of the cable that comes with these boats is acting like a screw and pulling water/grease into the hull...
          Just a guess. I need to look to confirm. Im sure you can do the same... Makes logical sense though.
          • electric
            • May 2008
            • 1744
            #80
            Originally posted by FighterCat57
            I'm having this same problem on the Apparition. Can't seem to figure out where the water is coming in. The next thing I'm going to try is to eliminate any extra space in between the prop dog and the strut. Since the hard prop shaft is captive, this might help reduce water intake if coming in via the shaft. I already have the shrink tube installed over the stuffing tube & strut and it did help reduce the shaft splatter.
            HTH
            Let me know how that works for you. I have thought about that to. I am concerned that even with that teflon washer between the drive dog and the strut that it will bind drive shaft and create issues...
            • electric
              • May 2008
              • 1744
              #81
              I checked that a night or two ago thinking the same thing. No luck. The wind is the same direction as "standard" shaft. Let me know if you see different.
              Well, I am calling it a night. I think I will do the shrink wrap around the strut and see if it improves.
              • electric
                • May 2008
                • 1744
                #82
                Originally posted by befu
                did I read your amp chart wrong? It looks like you are peaking at 90 amps and pulling in the 60 range once things settle down. It's listed as a 50 amp speed control!
                That seems like a lot of amps for a 3656 motor if I read that right. Longevity will be the next question.
                Yes, I noticed that to. However, I have seen simliar reading on a UL1 and a SV. It is amazing what you find out with a datalogger. Turns out that there are a lot of high peaks those ESC's deal with that I was never very aware of. Time will tell on the durability I suppose.
                • electric
                  • May 2008
                  • 1744
                  #83
                  Hey! Wait a minute! This may help. I have been leaving the 1/8 gap between the drive dog and strut, but with this odd design of the drive shaft there is no reason to.
                  The reason is you can snug it up (still turning freely) is because it is on the solid shaft and ridge on the shaft on the other side of the stut keeps the fore and aft distance on the strut constant. If the flex cable tries to pull the assembly inward when you thottle up it will not because it is free floating(not like most collets) so the square drive will just pull away from the collet a bit. This may be a major factor in the problem.
                  Something new to try.
                  • lectriglide
                    • 538
                    #84
                    I'm pretty sure all flex cables do this. That is the reason you leave a gap between the drive dog and strut. As they spin and create resistance, the cable "tightens" and shrinks. Think about it, if it were spinning against the "wrap", it would unravel (I know this from experience, had the motor running backwards and forgot to check).
                    Since I ruined the teflon tube with the unravelled flex cable, I just run without it but did notice a lot more water inside. Put a small piece of fuel tubing over the stuffing tube so only about 1/16 of an inch touches the flex cable and no more water!
                    • ray schrauwen
                      • 9472
                      #85
                      There is nice heatshrink with adhesive inside. I like it because the glue keeps the grease inside better.
                      Nortavlag Bulc
                      • D&D
                        • Aug 2009
                        • 185
                        #86
                        In a square drive system all of the pressure is at the drive dog and the strut. That teflon washer would normally be the only "bearing" (or thrust bearing) that is taking the pressure from your drive. Tried teflon years ago with nitro boats and the teflon bearing would not last long, they would crush. Areomarine makes a nice metal and platic (washer) bearing that works well with square drive systems.
                        • Graeme
                          • Jun 2010
                          • 90
                          #87
                          Well here is my first run of the boat I have the same problem with water coming up the shaft.
                          and here is the second run not much to say here I think water may have seeped into the esc.
                          They want me to ship the whole boat in for warranty I think It will be cheaper just to buy an new esc
                          • Basstronics
                            • Jun 2008
                            • 2345
                            #88
                            I would just throw a fit on that. What good is sending the entire boat in?
                            Just a hassle maneuver. jerks.
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #89
                              I would just eat it and get another esc you no how long shipping takes and being waranty it will be twice as long...
                              • Graeme
                                • Jun 2010
                                • 90
                                #90
                                I agree I just ordered another esc off ebay
