What Feigao 580l motor for a 37.5" Mono
  • agressive1
    • Feb 2010
    • 89
    Hello
    Iam wanting to purchase a motor for my 37.5" Mono hull although not to sure what to get i know i want a Feigao 580l because of the price but i dont want a motor that will completely kill my Seaking 180a esc. The boat will be running on 2x 22.2v 6s 5000mah Lipos in Parallel with a x460 prop.
    So i want it to be quick but i also want it to be reliable and not kill my ESC.
    For a heavier boat do you go for something more RPM reving or less RPM reving.
    The higher the RPM does it have more up and go or top end....?
    Im guessing a 12l would be slower then a 9l?
    Also would 12G wire be suited for my needs or should i go for the 10G?
    Thanks
    Dean
  • Darin Jordan
    • 8335
    Originally posted by agressive1
    Hello
    Thanks
    Dean
    You'll want torque, but 37.5" isn't really all that big... Target 25,000 to 30,000 RPM and you should be fine. I'd think something in the 1100-1200 KV range would be about right... Even for racing... Going to depend on what your planning on doing with the boat, but I think this range is safe even for Sport Boating... Would FLY!
    Darin E. Jordan - Renton, WA
      • 9488
      hey Darin, what about a Castle motor in this and in a 40" mono on 4s-5s?
      http://forums.offshoreelectrics.com/...ad.php?t=14350
      or would a 580 be better?
      thanks
      • Make-a-Wake
        FE Rules!
        • 5557
        Any more than the 12L will give you trouble with a an x460............its plenty.
        • Rumdog
          • 6453
          a x460 will be too big with any of those motors, and for that hull.
          • agressive1
            • Feb 2010
            • 89
            Ok so i will go for a smaller prop
            Do you think a Feigao 580 12l or a 9l or...?
            Yes do plan on doing some light racing with it.
            • vasy
              • Dec 2009
              • 333
              x460 too big? I use x464 ok.. (just at max)
              • Rumdog
                • 6453
                Ummm, with a Feigao 580? On a 37.5" mono?
                • vasy
                  • Dec 2009
                  • 333
                  deep vee.
                  • Flying Scotsman
                    Fast Electric Adict!
                    • Jun 2007
                    • 5190
                    An X460 is a pretty big prop, what ESC are you using?
                    I think that 180 amp will go poof on aggresive1's application
                    Douggie
                      • 9488
                      Originally posted by vasy
                      deep vee.
                      Mono
                      • Rumdog
                        • 6453
                        If the electronics don't fail, the boat will more than likely lay on it's side under power. I sure wouldn't run a prop that large on a Feigao 580!
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          I'd run an x645............12L
                          • agressive1
                            • Feb 2010
                            • 89
                            What other ESC is recommended then, yes i will be running a Seaking 180a
                            Anyother prop suggestions and motor size, 12L????
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              A seaking 180a is more then enough for that motor if you dont severely overprop it.
