Differences between high end ESC's and cheap ones for Lehner motors?
    • 7673
    #151
    The knife blade appears to be made out of a very strong yet flexible metal... with that in mind... I think it would act as a good shock absorber on impact
    But handling-wise would handling characteristics be similar to the stock wedge? That is... If I kept it slightly longer or same length.
    Umm, how flexible Dmitry? You don’t want it vibrating back there. Sorry I can’t help on the rudder design, I have a few designs to test but haven’t found the time at this point.
    • RaceMechaniX
      • Sep 2007
      • 2821
      #152
      The flexibility helps, but they will snap. The best rudder blades are very stiff. You do not want a wobbling rudder blade for SAW passes. Another point to add to Jay’s is it is preferable to have more chord length than depth of the rudder. Long skinny blades do not work as well as shorter wider blades. By wider blades I mean front to back distance not the trailing edge. As a general rule of thumb the rudder blade should be at minimum as deep as the prop plus a half prop diameter. So make sure the rudder extends below the lowest point of the prop(s). For the SAW cats I would recommend 40-50mm below the prop.
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • dmitry100
        • Mar 2015
        • 1264
        #153
        Any of you guys know of anyone who makes or can make decent blades?
        Tyler, the blades do NEED to be complete wedges right? Even if its 2x in chord length than the stock...
        My other (destroyed) Shocker cat never had any issues with rudder bends even after like 10 100mph+ crashes, and it was short in length but wide rudder... so I suppose that is the way to go.
        I found some decent wide blades on the H&M site... hopefully its not any thicker than my stock blade.
        • dmitry100
          • Mar 2015
          • 1264
          #154
          Look what I found on the HPr99 hull... This happened exactly in the same place where what there looked to be some sort of “dent” (bubble?) left during hpr’s vacuuming process...
          It looks as if a piece sort of “popped” out like a jig saw puzzle piece...
          As you can see there’s a smaller but similar bubble in the first picture below...
          hopefully this doesn’t cause the rest of the hull to crack after fixing ...
          • Lone-Wolf
            • Nov 2015
            • 276
            #155
            At least it's not on any of the running surfaces, should be an easy fix but that is unfortunate for such a high end hull.
            • dmitry100
              • Mar 2015
              • 1264
              #156
              Yea no biggie. Looks fixable... a bit of West systems epoxy + silica then some touch up paint and it should be fine. I think.
              I just figured it out: it’s emptiness. All that was covering that area was a layer white paint... so the recent crash must of simply pressed it.
              This is air bubble next to it that I pushed in...
              But ya, it is disappointing. I’m gonna assume it’s been known to happen.
              • slyautosports
                • May 2018
                • 5
                #157
                Guys I need your help... I am a land U4RC racer which esc's and motors figured with gearing are a snap but, these boat systems are a little confusing.
                Currently I have a ProMarine 34" MTR single motor with a Seaking 120a V3 ESC and 3674 2075kv brushless motor.
                I run both 4s and 6s and mostly just tear up the lakes with friends. Maybe I'll race later.
                I use both ABC 1715 prop (for 4s) and ABC 1716 prop for 6s.
                I use 2 Revolectrix 70c 3s 5800mah batts to get 6s.
                I want it fast with a decent runtime.
                Since I'm mostly bashing the boat I am not needing a high dollar system.
                Currently I'm considering a Swordfish X 220a ESC. And upgrading to a 40mm motor between 1600kv/1700kv.
                My questions;
                1) Do I need caps installed? If so which type and how many?
                2) Which motor would be best? Go 40mm or stay with 36mm? Which Kv?
                Any guidance would be great... as I am confused as to which setup and required specs I need.
                Thank you in advance
                Sent from my SM-N950U using Tapatalk
                • dmitry100
                  • Mar 2015
                  • 1264
                  #158
                  You should probably go with any of the Castle ICE/Phoenix 200 esc's converted to water... You can get them for under 200. Probably cheaper if used. If you want to get the most of it and be bulletproof. Alot of people have success with the cheaper Mamba XLX also.
                  Can't go wrong with 4000-5000uf total caps of Rubycon ZL class 470uf caps or any of the high ripple versions of UnitedChemicon caps.
                  For racing I would imagine you need maximum efficiency for longest battery life if you plan to race. So probably go with 36mm and around 1700-2000kv. Theres alot of other people here who have more experience with heat racing... so i'll assume they give you input.
                  • slyautosports
                    • May 2018
                    • 5
                    #159
                    Thank you for the info. I have searched and haven't found any water-cooled Castle ICE/Phoenix esc...
                    I would like to stick with turn-key off the shelf ESC's but trying to decide which one...
                    So far I've looked at Swordfish X 220a but is there something better that isn't hundreds of dollars...
                    ZTW or Etti?
                    I have read a lot of negative posts on Seaking 180a V3's.
                    • NativePaul
                      Greased Weasel
                      • 2760
                      #160
                      You can get pre-modified water cooled Castle ESCs from Gromov at ecomaster.torgg.com.
                      • dmitry100
                        • Mar 2015
                        • 1264
                        #161
                        YEa, i wouldn't trust the seaking 180 v3 too much... even I managed to blow one up without much effort.
                        ZTW 200a looks good. I hear they are pretty good quality. Etti is much pricier ... seems priced along lines of Castle.
                        • ray schrauwen
                          • 9472
                          #162
                          Can you give a screen shot of the right product? I mean I look for high ripple or low ESR and I really don't know what I'm looking at depending on which seller is listing specs.
                          Nortavlag Bulc
                          • donhuff
                            • Dec 2014
                            • 561
                            #163
                            Dmitry,
                            That's just a bubble on the inside where the cloth did not stay "stuck" to the gelcoat. It's real easy to get those when working the resin into the cloth. One has to be very careful when brushing/dabbing the resin into the cloth on one end of the boat, so that you don't pull the cloth on the other end of the part, and make those type bubbles. Especially with a carbon cloth like you have, as it does not drape as well as glass cloth does, and does not conform to the mold as well.
                            I vacuum bag my hulls to help reduce this, and to suck out the excess resin. You would think that the vacuum would pull the cloth into full contact with the mold, and it does for the most part. But I still have to make up a "putty" of resin, milled glass, and silica, and smear a radius into all corners of the hull. Chine, strakes, transom edges, all get a good filling before the layup starts.
                            Since you had those two bubbles, I'll bet that you probably have more. Take a steel rod or something hard and smooth like a butter knife handle, and go over all corners of the hull. Press hard while sliding it along the edges. If there is a bubble under the gelcoat, this usually will make it break through. Better to find it now than on the water.
                            If you'll send me one of your bent rudders, and the dimensions of what you want. I can get a piece of 7075 and make you one. But it will be a full wedge, and to make it strong enough, you need it to be 3/16 to 1/4 inch wide at the rear. Just don't be in a hurry for it cause I work slow!
                            I would not waste time with the knife blade, we tried one on my son's gas mono in Huntsville when going for a record. It was a little smaller than the speedmaster blade we took off, thinner and flat sided like what you have. The boat was UNCONTROLLABLE period. We took it off and put the big speedmaster back on, and on his next attempt, he set the current LSG36 Mono 1/3rd oval record. Control is mandatory, without control, speed means nothing.
                            AmpDaddy
                            don huff
                              • 7673
                              #164
                              BMW? Lol sorry Don, just had to
                              • donhuff
                                • Dec 2014
                                • 561
                                #165
                                BMW the automotive company?
                                If i'm re-quoting someone else, I didn't mean to. that's just the way I see it.
                                AmpDaddy
                                don huff
