Has anyone tried this new ESC in a boat? How about water cooling, is it simalar to converting the Mamba XL2?
Mamba XL X
Tags: None
It's the same case as the xl2 so easy to convert to water cooling.. Does have 4 more caps that make overall length longer.. As far as performance.. I like the adjustable bec.. And running the 2 back to back it runs on average 30 to 40 degrees cooler than the xl2 with same exact setup in same boat and motor and prop..and have spiked it well over 275 amps.. Just wish they were a bit more waterproof -
Thanks for the reply. One more quick question. How tall is the ESC after removing the heat sink and cooling fan and converting it to water cooling? I found some interesting comparisons of the xlx to the xl2 here
Electric On-Road - Castle XLX vs. XL2 - What's up guys? I know there are a few threads and some info out there on this subject already but I figured I'd post my findings and conclusion! Ok the main differences between the two are: XLX Current limiting: max of 260A but can be disabled Has the aux cable More caps XL2
and here
Sounds like they are doing this for warranty reasons...
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
They stopped the Hydra series several years ago. They stopped because they lost $$$ on every one due to all the warranty returns....close to 100 times the warranty claims versus airplane controllers. They should get props for hanging in so long.
The neutering of the Mamba is a disappointment, but I use the aircraft controllers modded for boat use. They make
wonderful controllers as long as they don't get wet.
I understand the warranty thing, but I (personally) would be reluctant to mod an airplane controller for boating use, if it can't get wet without failing, because that seems inevitable.
They should change their slogan to: THE FASTEST NAME IN RC (except for boats).Comment
The Hydras weren't tolerant of water either. Experienced boaters know how to keep water out of a boat. The Castles can be waterproofed (kinda) with CorrosionX if you doubt your skills. If you don't like Castle, don't buy one. No one is holding a gun to your head.
I'd like to see a boat lose it's hatch and not take on water...That's a good trick!!!....I have lots of Castle stuff..........................
So, I know Castle COULD build a superior BOAT ESC if they WANTED TO. If warranty returns were your problem, then build it BETTER!
They've become FAT & Sassy on their multi-MillionDollar TRAXXAS contracts and apparently don't care about boating as much, or expanding their line to encompass us all. It's about money, not the hobby anymore. GO TEAM CORPORATE AMERICA!!!!Comment
Anyone convert the 160 HV lite controller to water cooling for a 10s setup it says good for 3s to 12sComment
