Whiplash Sport 20 FE Build
    • 9479
    #151
    Great..
    There is a Whip20 on RCU I've thought about picking up..
    • ray schrauwen
      • 9438
      #152
      saw that too, I would rather build from kit, less work, better results..
      Nortavlag Bulc
        • 9479
        #153
        Ya, that's the thing for me as I really have no place to build one..
        Kinda sucks, and I'm not sure how much work that one needs to make electric?
        • haydn33
          • 1
          #154
          Originally posted by detox
          If painting hull be sure to use paint manufacturers matching primer and paint to prevent pealing when removing hatch tape. I used Summitracing's high build urethane primer surfacer. From the can this stuff is too thick to spray using 5mm tip HVLP gun. You must thin it down lots until it sprays well. Then I sprayed over primer using Summitracing's Urethane paint.
          The easiest and cheapest route is using Krylons matching primer and paint. I have had verygood luck with Krylon paint not pealing. Easy touch up also.
          Lots of beautiful Whiplashes out there that have been clear coated only. I do not know how they do that. Epoxy hull, sand, then spray clear?
          i've enjoyed your build thread, as far as the clear finish i wet sand the epoxy coating and then shoot some clear(sometimes no clear just wet sand the epoxy and then apply another coat when dried)
          • LuckyDuc
            Team Ducati Racing
            • Dec 2008
            • 989
            #155
            Conclusion to my Build Thread
            I just returned from the 2010 NAMBA Fast Electric Nationals in Greeley, CO and I am pleased to report that my Ducati Whiplash took 1st place in LSH and 2nd place in P-Sport Hydro.
            Thanks again to all of the sponsors and the NAMBA District 20 clubs for hosting a GREAT event! I made a lot of new friends there and learned some new tricks as well.
            A special thanks to Jeepers for his prop suggestion in P-sport, and to Teach for the flushing syringe.
              • 9479
              #156
              Congrats!
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 989
                #157
                Great pics! Thanks for posting them!
                  • 9479
                  #158
                  • ray schrauwen
                    • 9438
                    #159
                    Congrats!
                    Would you care to let us in on your setups please?
                    What kind of props etc...
                    Nortavlag Bulc
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 989
                      #160
                      Congrats!
                      No secrets here. It is all documented in the build thread along with the Eagle tree data.
                      • detox
                        • Jun 2008
                        • 2310
                        #161
                        Way to go LuckyDuc! Looks like you all had some nice weather. What hulls did you run against in LSH and P sport Hydro?
                        • Drag Boat Bob
                          • Apr 2009
                          • 304
                          #162
                          Congratulations Duc!
                          I'll toast a cool one to ya...
                          • LuckyDuc
                            Team Ducati Racing
                            • Dec 2008
                            • 989
                            #163
                            Thanks guys!
                            From what I remember the hulls included Whiplashes, Insane Hydros, UL-1s, Vacu-pickles, and BBY sport hydros. Sorry if I left any out.
                            David Newland did a great write up on the LSH race HERE
                            • detox
                              • Jun 2008
                              • 2310
                              #164
                              Cool write up. I bet you can get more speed out of your Whiplash. Batteries play a major role (more voltage = more kv). test, test, test
                              http://forums.offshoreelectrics.com/...ad.php?t=16937
                              • LuckyDuc
                                Team Ducati Racing
                                • Dec 2008
                                • 989
                                #165
                                Testing is DEFINITELY important. I never stop.
                                I could probably get more speed out of my Whiplash in LSH trim, but those same hull changes would make it too flighty in P-sport configuration. It was a sacrifice I made to have one hull that could work in both LSH and P-Sport classes. Besides, you need approximately 5-7mph more speed to pass someone on the outside. I'm in the right speed range. I just need to keep lane one every lap... And who is to say that I was running at 100% throttle
