Looks pretty sweet when its done...
Whiplash Sport 20 FE Build
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
I'm running the centerline of the strut parallel to the bottom of the sponson. Start out with ZERO angle. Use an M445 prop if running spec.Mini Cat Racing USA
So about 1/2-3/4 inch to the centreline of the strut ????/
M445, is this slightly overpropped ? i was thinking more a X442 or a Grim 42-55 , i know everyone has their own favourites here .
the 'M' in front of the numbers means Modified right??
Thanks againComment
Mine is slightly different, since I modded the sponsons to be 1/8" deeper I run it flat with the sponsons, at about 3/4" deep.
Nortavlag Bulc
The M445 will NOT overprop the boat if you run the strut correctly. All of us here are running that prop on our Whiplash'sMini Cat Racing USA
